Car sits uneven?
Old May 24, 2009 | 12:19 PM
cturnbull802's Avatar
cturnbull802
i am going to check out the rubber isolator mount and see if any height can be had there, if that doesnt work i guess cutting a 1/4 coil at a time will be my only option.
Old May 24, 2009 | 03:01 PM
JonnyRod's Avatar
JonnyRod
its crazy...i thought I was the only one...
Old May 24, 2009 | 07:03 PM
freedonutss's Avatar
freedonutss
I have lowering springs and its the same with me. I probably just park on uneven surfaces because depending on where I park, the drivers side usually has more fender gap but sometimes the passenger side has fender gap. Its never even
Old May 24, 2009 | 09:29 PM
JonnyRod's Avatar
JonnyRod
Originally Posted by cturnbull802
honestly if mine was the rear it wouldnt bother me nearly as much. but its the front. so on my passenger side i have more of a gap in the front than the back.. i have all week off work so i will mess with it and see if i can come up with a fix.
my experience with coilovers is they ride like **** on the streets. ( i live outside detroit and roads here are always bad due to the freeze and thaw cycles all winter long)
i also talked with an engineer that builds race cars, and his thoughts were for a street car you will gain more handing from a set of sway bars than you will with a set of fully adjustable coilovers.
My front is like that too...its both
Old May 24, 2009 | 09:56 PM
SchismX's Avatar
SchismX
It's just the nature of the beast. Sometimes springs in a kit, whether it's front or back, are not manufactured to exact lengths of one another so one side sits slightly higher than the other. It doesn't bother me much anymore. I've tried adjusting my coilovers to get it as close as possible, but I can never win lol.
Old May 24, 2009 | 10:27 PM
JonnyRod's Avatar
JonnyRod
But why would STOCK suspension be like that? have you seen my pics? is this similar to the way everyone elses Z sits?
Old May 25, 2009 | 09:39 AM
terrasmak's Avatar
Probably cause the car is hardly ever parked on a perfectly even road , or better yet , FUEL changes everything.
Old May 25, 2009 | 10:32 AM
JonnyRod's Avatar
JonnyRod
As far as the uneven roads go...not my case. My car ALWAYS sits like that...level or not
Old May 25, 2009 | 11:33 AM
jdella681's Avatar
jdella681
I was thinking maybe its the gas but even with less than a quarter left my passenger side sits just a bit lower ;(
Old May 26, 2009 | 04:29 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
1. the car does not have the same weight per corner
2. springs, over time, can sag - stock, aftermarket, doesn't matter
3. the struts, over time, can sag, and not rebound fully (fronts).
4. manufacturing differences from one spring to another
5. luck of the draw. Some cars will get this, no matter what springs they use, others won't
all will controbute to the scenario. If you want the car to be 100% even, coilovers are the only way to accomplish it
Old May 26, 2009 | 09:08 AM
danimaldaisy's Avatar
danimaldaisy
back in the day...it was the coil overs were the ONLY way to get my civic to sit evenly.
It mostly has to do with QQ from the factory cause i had this problem from day one.
Thankful that my Z does not have this problem
etkms
Jun 19, 2022 06:30 PM
StreetStandard
Videos
Feb 4, 2016 09:44 AM
AbyteZero
Sep 22, 2015 09:17 AM
CJs_Z33
Sep 18, 2015 12:06 PM
Mw870
Sep 10, 2015 07:50 PM
