What do you think happened to my rotor?
Old Jun 8, 2009 | 03:11 PM
Xzero's Avatar
Xzero
Default What do you think happened to my rotor?
I installed the OEM Bremos on my car about 1000km ago( see thread: https://my350z.com/forum/brakes-and-...onversion.html ) & since bedding in my brakes, my left rear rotor has looked like this:
It has criss-cross lines of brake pad residue? on it. There is no scoring or gouges in the rotor, when I touch it with my fingers its pretty smooth, you can just see that criss-cross pattern. It *seems* to be going away, I can see the regular wear pattern coming through, but I dont know what caused it. It is also happening on the opposite side of the rotor.
I have taken my pads out & inspected them, they are wearing perfectly fine & have no abnormal wear. Im just really stumped as to why this criss-cross pattern is there & how it is so perfectly done. Has anyone seen this before or have any ideas?
Old Jun 8, 2009 | 03:56 PM
Anomaly's Avatar
Anomaly
Those look like machining marks.
They're present in your just installed pics too:
warmmilk's Avatar
warmmilk
that not an oem/brembo rotor is it? it looks like your rotor material is wearing away. if you look at your other thread, you can already see the criss cross pattern a little bit. I'd get some better quality rotors...
Old Jun 8, 2009 | 04:05 PM
DavesZ#3's Avatar
DavesZ#3
The criss-cross lines are the machine marks from where the rotors were ground flat initially. Now, they're becoming more visible as they fill with brake dust. It's all normal.
All of your rotors should have looked like that initially.
Old Jun 8, 2009 | 04:09 PM
Xzero's Avatar
Xzero
Thanks for the info! To be honest, my other rotors looked "normal", as in regular brake pad wear marks, pretty much right after the bed-in. At least I know its nothing irregular!
Old Jun 8, 2009 | 04:11 PM
Xzero's Avatar
Xzero
They are POWERSLOT rotors, sister company of STOP-TECH. The rotors are of quality. Yup, you can see the criss-cross pattern in my other pics, but its slowly fading now.
Old Jun 8, 2009 | 04:16 PM
Xzero's Avatar
Xzero
Yup, thats a pic from right after the bed-in & 1000km later, the marks are still there but fading. I'll take yours & Daves word that its just machine marks. It would make sense as I can't find ANYTHING else wrong with the set-up.
Old Jun 8, 2009 | 04:36 PM
DavesZ#3's Avatar
DavesZ#3
That one rotor may have been more heavily scored than the other three and now it's just more noticible. Eventually the cross-hatch pattern will be replaced by the normal radial scoring from the pads.
Old Jun 8, 2009 | 04:59 PM
warmmilk's Avatar
warmmilk
the thing that has me concerned is the rusting going on in this pic, closest to the center of the rotor...
Old Jun 8, 2009 | 05:00 PM
warmmilk's Avatar
warmmilk
although now that i look at it, just looks like some surface rust... at first it looked like it was deep rust to me for some reason... my bad
Old Jun 8, 2009 | 05:41 PM
Xzero's Avatar
Xzero
Its not rust, its just a build up of brake dust residue. I went & checked just to make sure. If they were rusting after 1000km, they'd be getting sent back with a nasty letter
Old Jun 9, 2009 | 06:58 AM
GeauxLadyZ's Avatar
GeauxLadyZ
/\ Ya that's just brake dust.
Old Jun 9, 2009 | 07:01 AM
tecni's Avatar
tecni
Do the brakes feel weird? Did you spray Brakeleen on them to remove the rust proof coating they come packaged with?
Old Jun 9, 2009 | 09:26 AM
warmmilk's Avatar
warmmilk
on the pic it looks kinda porous where all the brake dust is. is it actually porous or is it solid?
Old Jun 9, 2009 | 11:57 AM
thekinn's Avatar
thekinn
As the others said ^ It looks normal. I recall the same pattern on my Powerslots when I first installed them.
Old Jun 9, 2009 | 12:44 PM
bryan@Z1's Avatar
bryan@Z1
Vendor - Former Vendor
Yep.
Old Jun 10, 2009 | 03:03 PM
Road Warrior's Avatar
Road Warrior
i sure hope not...they specifically state to use soap and water and NOT brake cleaner
Old Jun 10, 2009 | 06:34 PM
=Cerberus='s Avatar
=Cerberus=
Start stepping on your brakes harder.
Old Jun 11, 2009 | 01:55 AM
TEF's Avatar
TEF
The cross-hatched grinding marks are from the manufacturing process. After turning the rotor faces on a lathe, the result is a fine spiral groove appearing fine parallel lines. To remove these unwanted grooves, rotor faces are then ground almost at a right angles (to the lathe groves) and hence the hatched markes. One gets the same results, when a shop re-faces rotors deeply scored from worn pads. Initially a lathe removes the damaged face and the rotor is then finished with a surface grinder (to remove the tool marks from the lathe). Both operation are done while the rotor spins. In short the marks on your rotors are not defects, but actually evidence that they were properly manufactured.
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
Stevo Z
Oct 3, 2015 09:14 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
samansharif
Sep 25, 2015 12:31 PM
