Ceramic pads on oem 06+ non-Brembo rotors?
Old Jun 23, 2009 | 08:01 AM
305LOPEZ's Avatar
305LOPEZ
Exclamation Ceramic pads on oem 06+ non-Brembo rotors?
-Good idea or bad? The reason for my question is because I have read in other threads how the quality grade of the OEM rotors is not up to par with the ceramic compound used in most of the high end brake pad. My concern is that after I use these pads would it cause any type of warping or uneven wear on the rotor, causing me to resurface them before time.
Thanks for all input and if there is a thread already open in regards to this, please excuse me.
Old Jun 23, 2009 | 09:34 AM
I have seen no independent testing showing type of pad versus rotor wear. Put the same pads on the same axle and you are good to go.
350z82
Oct 1, 2015 06:25 PM
