Assuming it's an '07 with stock 18" wheels and tires, the distance from the top of the front wheel opening to ground should be 683mm, the rear should be 706mm.
thanks, just did the measuring and it came out to 666.75 mm in the front. I guess it is lowered..
Is your car the same year with the same wheel size as Davesz#3 is talking about?. That car does not look lowered but there is nothing wrong with keeping the "drop illussion"
Looks stock to me. I've got an 08 with the same wheels at stock height. Pics don't show a very good view of the wheel gap, but I think its close enough.
DAVEZ post is most likely the measurements given in the factory service manual. which if your car is like he says, then those should be the measurements...
its kinda silly for all of us to "guess" because thats about all we can do........you obviously own a camera, so if you want to "know for sure" then climb under the rear and take a pic of the spring, and do your best to take a pick of the spring/shock combo up front and then instead of guessing you can get a definite answer...
Pretty much the best way to tell is to look at your suspension and compare!
