need help for my JICs
Old Oct 1, 2003 | 07:49 PM
Z33@TOR's Avatar
Z33@TOR
Default need help for my JICs
dear JIC owners,
after i installed my JIC flt-a2, i hear some clunking noises from the rear right corner whenever i go over some bumpy roads.
the mechanic tried switching the 2 rear coilovers to test where the noises were coming from and to see if the noises will change sides....noises have reduced but it's still there at the rear right corner
any idea where the noises are coming from?
the mechanic said it might be the sway bar that produced the noises becoz i have lowered the car....
Old Oct 1, 2003 | 10:08 PM
Topics II's Avatar
Topics II
do you have the upper rubber mounts for the springs? I had some squeaking noises as well before i got the rubber spring perches in there.
Old Oct 2, 2003 | 03:55 AM
John's Avatar
John
The clunking sound is inherit in the design of the JICs, and even the Teins from what I understand. I initially didn't have the upper rubber spring mount, but once I received and installed it, the sound diminished, but was still there.
Old Oct 2, 2003 | 07:03 AM
Z33@TOR's Avatar
Z33@TOR
i have the rubber pieces installed with the springs
only the rear right corner has this noise
if the noise is inherit in the JIC or Tein i should have got the HKS Hipermax II/Pro coilovers then....i had that on me IS300 and it was very quiet.
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
Z33@TOR
Aug 21, 2003 10:47 AM
valuetl
Feb 15, 2003 04:49 AM
Matt XX
Jan 29, 2003 07:32 AM
Traffic
Nov 19, 2002 08:31 PM
