abs and brake light stays on?
Old Jul 19, 2009 | 11:39 AM
miickeyxd's Avatar
miickeyxd
Default abs and brake light stays on?
anyone have this happen? when the abs and brake light stays on constantly, thanks.
Old Jul 19, 2009 | 12:42 PM
DavesZ#3's Avatar
DavesZ#3
Check for low brake fluid then check for worn pads.
Old Jul 19, 2009 | 05:37 PM
miickeyxd's Avatar
miickeyxd
Alright, thanks. Anything else I should check?
Old Jul 20, 2009 | 03:22 AM
DavesZ#3's Avatar
DavesZ#3
Those are the easiest thing and the most common. Low fluid normally causes the Brake light to stay on.
Old Jul 20, 2009 | 06:13 AM
miickeyxd's Avatar
miickeyxd
so check my brake fluid and it was good, anything else?
Old Jul 20, 2009 | 09:17 AM
DavesZ#3's Avatar
DavesZ#3
Are the pads worn out? That would be the next thing to check.
Old Jul 20, 2009 | 04:38 PM
gregom's Avatar
gregom
Worn pads could cause your fluid to be low, thus causing the warning light to come on. You could just add fluid but that wont really fix the problem, plus if you do change the pads and don't bleed the system, you will likely overfill the reservoir when you push the pistons back in. It would be best just to change the pads if they are almost gone.
Oh another thing to check, I know its really simple... but your emergency brake, make sure it isn't slightly engaged.
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
