S-tech settlement
Old Sep 4, 2009 | 08:46 AM
o2sys's Avatar
o2sys
Default S-tech settlement
This is what I get for lying to myself I searched the forums inside and out and came to a conclusion that S-techs were the springs for me. I saw settled pix with springmount mods and they looked great!
The springmounts took care of the wheel gap on the rear but the front doesn't look lowered at all. I kept saying to myself once they settle it will go away and etc, etc...
Does this look fully settled to you? Its the angle i took the picture but from a leveled view there still a good gap on the fronts.
UPDATES:9/11/09
My driver side front sits about 1/2" higher than my passenger side. So from profile view the fronts now sits higher than the rear!
i read couple threads about heights not always being the same left to right because of independent suspension but 1/2"????? There goes the drop the s-techs provide.
Could it be that the top hat was not tightened enough??? I dont get any noise from it and when i visually inspect, everything is tight.
Is it possible to "try" to tighten the 17mm bolt on the top while its on the car???
PLEASE HELP~
UPDATE 9/26/09:
Hoping the springs would settle a bit more here are some final measurement for the fronts only. Measured from ground to fender.
Driver side 673.1mm
Pass. side 666.75mm
OEM is 683mm, so passenger side lower to advertised 17mm drop, the driver side only 10mm. I mean 7mm is not a lot but on the actual car it makes a huge difference. I'm being **** but isn't everyone?
Would the upper rubber mount or something not make it sit right? Should i bother re-installing the driver side?
Measurement where measured in the flattest pavement possible. I took measurements in various locations and got the same figures.
Old Sep 4, 2009 | 08:50 AM
GeauxLadyZ's Avatar
GeauxLadyZ
Yup, that looks about right.
Old Sep 4, 2009 | 08:56 AM
CG350z's Avatar
CG350z
That looks really good. Need some wheel spacers tho.
Old Sep 4, 2009 | 09:07 AM
Brrcats's Avatar
Brrcats
yup, looks about what mine is at after 3 weeks, I didnt do the spring mount mod though, I prefer to keep the rake, not that it really makes a difference, but I like the stance better with the rake
Old Sep 4, 2009 | 09:08 AM
o2sys's Avatar
o2sys
Already has 20MM Front and 25MM Rear and I'm having rubbing issues at the rear at the moment even with fenders rolled (camber not to spec)
o2sys's Avatar
o2sys
So i guess is either i shut up and keep em or get Eibachs or GF210's....
Old Sep 4, 2009 | 09:09 AM
vthao's Avatar
vthao
Remember, S-Techs lower the car less than an inch. In your pic, you can tell the car is lowered....on S-techs.
Old Sep 4, 2009 | 09:11 AM
o2sys's Avatar
o2sys
Yea, i know now im wishing it was lower...
Old Sep 6, 2009 | 09:17 PM
GeauxLadyZ's Avatar
GeauxLadyZ
Yes...the s-tech is a little drop on an already low car.
I would like alittle lower as well, but im not a fan of ripping up my FRP kits.
Old Sep 7, 2009 | 08:50 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
lowering the car more than that on springs is compromising any semblence of handling that the car may have had, especially on early struts, like your car has. If the car is already rubbing now, lowering more isn't going to help. Go compare your car to a stock Z - you'll see it does in fact look lowered. Get the alignment issues solved, and if you want it lower, then the proper route is coilovers
Old Sep 8, 2009 | 06:32 PM
69 fingers's Avatar
69 fingers
I just put on S-techs around 3 weeks ago myself, and I feel like my car is almost too low. Lowering it much more than what the S-techs provides will make it more difficult to be a daily driver but if you got another ride, do it up!
Old Sep 11, 2009 | 08:24 AM
o2sys's Avatar
o2sys
updated on issue, please help
Old Sep 11, 2009 | 09:00 AM
Gsedan35's Avatar
Gsedan35
Originally Posted by o2sys
UPDATES:9/11/09
PLEASE HELP~
Don't bother with the 17mm bolt at the piston shaft/upper shock mount, it would rattle really bad if it's ever not tightened, you'd know trust me. It's not uncommon for these car's to have a uneven drop as noted.
What if the rear upper spring seats that you cut, weren't cut evenly?
Did you install front camber arms with the spring install or make a adjustment to arms you already had installed?
When you tightened the rear toe cam bolts after wrapping up the spring install, did you make sure that both spring buckets were the same height as each other?
Has the car been aligned since the spring install?
Old Sep 11, 2009 | 09:11 AM
o2sys's Avatar
o2sys
the spring mount were machine cut and were done as straight as possible and measured before remounting them. Im sure there was slight micro mm difference but could not have been detected by human eye.
I didn't install front camber arms.re-used stock. The car has been aligned and toe and camber came back to spec. Well the rears were at -2.0 camber.
Old Sep 11, 2009 | 09:12 AM
Z1 Performance
Former Sponsor
1. make sure the ground you are taking these measurements on is 100% level. If it's not, you won't be measuring anything with any grade of accuracy
2. were you sure your shocks are in good shape, and fully rebounding before you installed your springs - did you compare their length side to side after taking the OEM spring off? If you have one side that is wearing, or worn, and is pre-compressed, that will also lead to an uneven ride height
Old Sep 11, 2009 | 09:19 AM
o2sys's Avatar
o2sys
I honestly didn't check if the shocks were good or not the oem shocks and the car have less than 15k miles on them but i'm sure they can go bad prematurely.
But during the install i noticed no abnormality of the shocks compression and rebound.
Old Sep 26, 2009 | 09:26 AM
o2sys's Avatar
o2sys
bump with updates on the first post, help please.
Old Sep 26, 2009 | 09:44 AM
Z1 Performance
Former Sponsor
perfectly normal to get a difference from one side to another. The car doesn't carry the same weight left to right, as such, the car won't sit exactly the same left to right either, unless you get coilovers. If the mount wasn't installed correctly, you would know it...it would make noise
Old Sep 26, 2009 | 03:09 PM
kensin0429's Avatar
kensin0429
which one lower the car more s tech / h tech / nf210 ?
i just want an 1 inch drop
im now with nf210 and its too low
i want to bring it up a bit
h tech or s tech ?
Old Sep 27, 2009 | 06:08 AM
Adrians07Z's Avatar
Adrians07Z
Driver side 673.1mm
Pass. side 666.75mm
Gain some weight
That'll level it out when your IN the car
