Hotchkis Swaybars and OEM Suspension
Old Oct 7, 2009 | 11:07 AM
TCO's Avatar
TCO
Default Hotchkis Swaybars and OEM Suspension
hi!
i bought some hotchkis swaybars and want to improve my oem suspension with them ... does anyone have some recommandation how to setup the sways?!
thanks!
thomas
Old Oct 7, 2009 | 01:20 PM
dennisafrompa's Avatar
dennisafrompa
....2nd hole from front on the front and softest setting in the rear (first hole) works very well for me at AX.
I'm on a square setup with 8.5 "x18s all around and 245 Dunlap Star Specs.
38psi front 41 psi rear.
Old Oct 7, 2009 | 02:00 PM
terrasmak's Avatar
He's not running a square tire setup , he should run the front bar one hole back from you for a little more front end bite and reduced understeer.
Old Oct 7, 2009 | 10:00 PM
TCO's Avatar
TCO
z1auto describes the hotchkis swaybars following (it's not the same as i read in the swaybar database https://my350z.com/forum/brakes-and-...-database.html )
Front
Rate Increase over stock
+22%, +48%, +82%, +129%
Rear
+80%, +125%, +185%
so i think the setup terasmak recommend is +22% Front and +80% Rear, isn't it?!
thomas
Old Oct 8, 2009 | 06:35 AM
terrasmak's Avatar
Front
Rear
+80%, +125%, +185%
thomas
Nope, i'm saying 48% front and 80% rear. The guy above me said 82% front and 80% rear and that doesn't help any on a car that is still running the factory tire stagger, but about perfect for a car running a square setup.
I ran that combo for a long time on stock springs and struts, works great. Now if you running ultra sticky rubber, coilovers , different tire stagger etc etc , its a good starting point for dialing things in.
Old Oct 8, 2009 | 07:03 AM
TCO's Avatar
TCO
okay ... thanks ... i will try this setup first and i think it's a good starting basis for my trial and error
350z82
Oct 1, 2015 06:25 PM
