Subaru Brembo calipers brakes and rotors on a Z?
Hey guys, my friend has an 06 WRX STI and upgraded from his brembos and will give them to me for a killer price, their bolt pattern is 5x114 i believe and ours is 5x114.3 is it possible to put the brembos on our car? what would need to be done to make it work if anyone knows or has done this? please let me know so i can either buy his stuff or he can sell it. Thanks for anyones input!
prob end up costing you more money in the long run, like everybody else that tries to do these car to car conversions.
Moot point, but dont the STI's brembos have a large "STI" engraved in them instead of Brembo?
These just say Brembo, but i have seen the ones with STI engraved, this if from an 06' if that makes a difference for years with the engraving or not... Id do the swap but garage time will be awhile to just try so it will cost money just to figure it out, was wondering if anyone had tried before or knew exact specs on what to do or is needed to do.
you'll have to measure the piston sizes that come off the STI to see if it will have enough stopping power for our Z as the weight distribution is different in both cars. you may inadvertently be biasing the braking power...(either too much front or worse. too much rear which might cause a lock up in RWD)
not only that you will need to see if the knuckle will fit the caliper bolt spacing for the STI and create/machine a bracket to adapt it to the correct rotor size for the Z.. just because it is 5x114 as well, doesn't mean the rotor will be properly spaced / aligned with the center of the caliper after it's installed... there's alot more to think about than just "bolting it on and running the brake lines"
neither the calipers nor the rotors will fit
the rotors have a much different offset vs the Z, and the calipers mount in totally different ways
brembos for the Z are fairly easy to locate, and you won't need to worry about fabbing anything
Thanks for the input everyone! I will most likely just tell him to sell on his own and ill be on the look out in marketplace for brembo's for my Z, if anyone has any or knows of any for sale shoot me a pm! Thanks again for the answers and help
Hmm ok just internet rumors i guess. i had heard that they were even the same calipers as the 1st gen CTSV, so i was gonna swap some gold brembos on my V if i ever had the money. thanks for clearing that up tho
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
