Clunk From Front End??
Old Oct 14, 2009 | 04:30 PM
striker27's Avatar
striker27
Default Clunk From Front End??
Sometimes after I park my car and then go to pull away I hear a clunk from the front end drivers side. It has happened a few times well brakeing and going into a left hand turn as well.
Any ideas on what this can be??? I have a power steering leak that is becoming a bit of a problem as well near one of the boots... I think it is due to not driving the car that much!!!
Old Oct 14, 2009 | 05:02 PM
dragon24's Avatar
dragon24
i had a few clunks in the front, found out it was my front sway bar from the bushings.
Old Oct 15, 2009 | 09:40 AM
guitman32's Avatar
guitman32
What year is your Z? There is a TSB for front end clunking on the earlier models, which is caused by the front upper A arm bolts coming slightly loose. Re-torque the bolts and you're set.
http://www.myzroadster.com/Files/tsb...NTB03-088a.pdf
If that doesn't work, then it's probably your end links or sway bar bushings.
Old Oct 15, 2009 | 10:30 AM
striker27's Avatar
striker27
My Z is a 2003.....
Old Oct 18, 2009 | 05:52 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
it could be any number of things - your best bet is to have a qualified shop go over the front end in detail
Obadabot
Jun 18, 2023 11:31 PM
Pleask
Dec 21, 2021 03:17 PM
pr_350z
Oct 1, 2015 05:03 PM
