Camber Issues HELP!
Old Oct 30, 2009 | 07:20 PM
Blck350z's Avatar
Blck350z
"davidv" if by swap u mean rotate from left to right then No....
"AznSky" Unfortunatley I do not have an exact mileage since these have been used for about 3 summers.. And they were also on my '06.... My best estimate is 10k- 13k miles. Yet up until I lowered it they did not have any abnormal wear... Which would have been about 2500 miles ago.
Looks like I will be taking this to firestone this coming week.....
Old Nov 4, 2009 | 05:48 PM
Blck350z's Avatar
Blck350z
BUMP: Any other idea's????
Old Nov 5, 2009 | 05:08 AM
sektor 11's Avatar
sektor 11
the #'s on your spec sheet look good. I would be curious to see a spec sheet now and pictures from what the tires looked like before the original alignment.
Old Nov 5, 2009 | 09:00 AM
Blck350z's Avatar
Blck350z
sektor 11... I am going for another alignment next week..... unfortunately I do not have a pic of before.... but I can tell you they were worn like the front tires with a little less tread on them ( i.e. because they are the rears and they went through a few weeks with F/I )
Old Nov 6, 2009 | 03:03 AM
sektor 11's Avatar
sektor 11
post up your alignment specs next week when you get them! You've got me curious as to what the diagnosis is going to be.
Old Nov 6, 2009 | 04:16 AM
AznSky's Avatar
AznSky
wait, i'm curious why you're getting an alignment again? Didn't the previous one already show OK specs?
It must be something else....
Old Nov 6, 2009 | 09:59 AM
Blck350z's Avatar
Blck350z
^^If you have any ideas I'm more than open to listening.... I waited for my springs to settle and got the alignment... and as you can see in the pics the tires are def. worn on the inside!!....
Old Mar 4, 2010 | 02:23 PM
nelson83099's Avatar
nelson83099
So any word on this out of curiosity? I just took my car out of storage and noticed i have the same problem.. Haven't got an alignment yet but i think my camber is off like a ****.
Old Mar 4, 2010 | 10:02 PM
terrasmak's Avatar
Just a quick FYI, running negative camber -1 to around -2.5 really doesn't eat the tires up unless your spinning them all the time. Toe is what is killing the tires, toe goes out all the time on the Z.
If your running camber arms, get a lockout kit from SPL, it will help keep the toe setting from going out.
Old Mar 5, 2010 | 03:22 PM
rsoto20's Avatar
rsoto20
i have this problem as well but really bad i mean ti the point where my tires went bald in like 3 months and it was ever since i had put the spc camber rear kit on and they told me it was my toe idk how my alignment guy cant adjust it right
Old Mar 7, 2010 | 11:37 PM
terrasmak's Avatar
The camber kit was probably installed wrong , please post a pic of your camber arms installed on your car. We really need to see the inboard mounting bolts for your camber arms.
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
350z82
Oct 1, 2015 06:25 PM
