06 caliper swap for an 03 question
hey everyone, i'm in the process of swapping out the front calipers on my 03 with the 06 calipers and was curious to see if i needed the 06 caliper mounting bracket for the install or would the 03 suffice? i understand the calipers and rotors up front are bigger but before taking anything off i just wanted to make sure...and if i do need to get a different mounting bracket where would i get such part and for how much?
Thanks in advance!
Thanks in advance!
and i've searched the forums and didn't come up with a definite answer...i've read that it will fit without any mods, triming the dust shield, and i need a mounting bracket....can anyone give me a definite answer?
You will need the bracket, i've done it. The caliper is larger , and the bracket that hold its is also larger/made to fit the different caliper and rotor.
The rear, only the bracket and rotors is needed. The calipers are the same.
Thats what I am saying, you have to have the whole caliper assembly. Just not the caliper.
