HKS Springs?
Old Dec 9, 2009 | 03:28 PM
ReV2Red's Avatar
ReV2Red
I haz da turbos
Default HKS Springs?
Anyone know an HKS dealer that holds HKS springs. I know HKS Japan sell different spring rates on their setups but i was just wondering if there are any US dealers that have them.
I'm looking for 10kg springs for the Hipermax III coilovers.
Old Dec 12, 2009 | 06:33 AM
ReV2Red's Avatar
ReV2Red
I haz da turbos
bump
Old Dec 12, 2009 | 06:52 AM
*Boose*'s Avatar
*Boose*
Might want to try bulletproofautomotive. They carry an extensive amount of japanese company parts that are hard to find. They are a vendor also.
Old Dec 12, 2009 | 09:34 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
You don't need an HKS spring. They don't make their own springs, so all you need to know is the ID and length - Eibach, Swift, H&R, Tanabe, and others all sell universal race springs in various ID and lengths that you could use. I'd be at least 1, if not all, make them in the measurements you need for the front. For the rear, it is more difficult
your options for the rear
1. measure the ID of the rear spring top and bottom from HKS, as well as length, and match it up to one of the other brands to see if it will work
2. buy the SPL rear midlink and then choose your own spring rate, as it uses a conventional diameter/length race spring
3. contact hyperco (or similar, there are many out there) and give them the measurements and see if they will make you something
Personally, I would not even bother - it would take some very sophisticated datalogging equipment and literally hundreds of hours of logs to know if a 1 kg/mm change (~56 lbs) is even necessary or beneficial
Old Dec 12, 2009 | 04:07 PM
ReV2Red's Avatar
ReV2Red
I haz da turbos
Thanks for your input. I'll see how it go's at the next track event and then make my decision from there.
Old Dec 12, 2009 | 04:12 PM
Z1 Performance
Former Sponsor
I wouldn't let 1 track day determine your spring rate choice
Old Dec 12, 2009 | 06:08 PM
ReV2Red's Avatar
ReV2Red
I haz da turbos
I mean the next competitive one. I've already done three track days with these coilovers. I just want to see how well i do on the next event and then take it from there.
The coilovers are great, but i just want to reduce the body roll a bit more. I definitely feel as though the dampers could handle and extra kg/mm with affecting the dampening. Although as you say, you would need a lot of testing to see if its actually made any benefit.
Still with the extra kg i should be able to reduce the roll a bit.
Old Dec 13, 2009 | 08:00 AM
Z1 Performance
Former Sponsor
body roll can and should be adjusted via sways, not via springs
Old Dec 13, 2009 | 12:09 PM
ReV2Red's Avatar
ReV2Red
I haz da turbos
I've been told that the sways should only be there to assist the springs.
Either way my progress sway bars are already at full stiff when i'm on the track.
Old Dec 14, 2009 | 07:17 PM
*Boose*'s Avatar
*Boose*
This may sound dumb but have you adjusted the coilover?
Old Dec 15, 2009 | 03:17 PM
ReV2Red's Avatar
ReV2Red
I haz da turbos
Yeah. I've had it at full stiff. The dampening is great, i just need a little less body roll.
EnjukuRacing
Sep 30, 2015 06:55 AM
