car scraping when going over bumps
Old Dec 14, 2009 | 08:36 PM
kevincat's Avatar
kevincat
Originally Posted by cow
Remove the wheels & ride on rotors. Problem solved.
Old Dec 14, 2009 | 08:37 PM
jduet's Avatar
jduet
Thanks Jon, here is what he's talking about...
Old Dec 14, 2009 | 08:56 PM
sdZ33's Avatar
sdZ33
You must be the most interesting man in the world...lol
Sick avatar...
Old Dec 14, 2009 | 09:00 PM
Waiz's Avatar
Waiz
Stop driving over speed bumps.
Problem Solved.
That will be $100 for my billed services.
Old Dec 14, 2009 | 09:36 PM
kevincat's Avatar
kevincat
Problem Solved.
haha pm me ur paypal.
but seriously, i really wouldnt care until i had to drive to homedepot with my girl, and they have these deadly speedbumps and my car just scraped like crazy. (shes only 100 lbs)
Old Dec 14, 2009 | 11:13 PM
ImWeeZzel's Avatar
ImWeeZzel
pics of 100lb girl or it didnt happen...
Old Dec 14, 2009 | 11:15 PM
terrasmak's Avatar
Originally Posted by kevincat
have any of you guys experience the shifter being hit and moved during a bump?
That would be the cats hitting, thecats are attached to the tranny, shifter conected to shifter. Your tranny mount may be bad making it seam a lot worse than it should actually be.
Old Dec 14, 2009 | 11:33 PM
350Zdj's Avatar
350Zdj
OP are u running on stock wheels?
if so,
you can also do this:
get yourself 18x9.5 rims plus
255/40 18
275/40 18's
this should give you extra 1 to 1.5 cm more clearance from stock
OR
get 19"er's
Old Dec 15, 2009 | 01:50 AM
duro78's Avatar
duro78
lift it back up to stock problem solved. Try driving in ny
Old Dec 15, 2009 | 01:54 AM
Ziggyrama's Avatar
Ziggyrama
Guys, he's scraping on stechs which barely drop the car to begin with. And you're telling him to get coils which is most likely drop it even more? That makes no sense.
OP, there's no magic solution here. You either need to:
1. Raise the car to increase ground clearance
2. Stop going to home depot with your car
You won't be able to remove anything from under the car to make it all better. Sorry to be the bearer of bad news.
Old Dec 15, 2009 | 03:29 AM
_STEVEO_01's Avatar
_STEVEO_01
Apparently, 1.) and 2.) were too hard to figure out.
Old Dec 15, 2009 | 04:46 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Why G35 springs? I have Z S-Techs and go over speed bumps everyday with no problems.
Old Dec 15, 2009 | 05:18 AM
JasonZ-YA's Avatar
JasonZ-YA
Okay your on springs.....meaning you hit a bump and your car "spring" bounces..the stock shocks are not great at controlling dampening.....so the bounce is inevitable - NO ADJUST ABILITY!!!
Were talking your existing drop you have NOW...
COILOVERS:
If you were to purchase coilovers and get to your EXACT same drop height then you can adjust your dampening on your coilovers and the spring perch on the coilover spring to stiffer and limit the "bounce" of the car.....thus helping the situation....
however, yes, the lower you go, the closer you get to speed bumps......
obviously, avoid speed bumps where possible.......I too drive to home depot, mainly in my Xterra, but if i would take the Z, drive through the rear of the parking lot then pull up closer to park.....
again,
you can not even remotely get close to the quality and adjustability of a coilover over just a spring set up........coilovers you get full adjusability - ride height, dampening, spring stiffening, etc......"quality" depends on the coilover purchased...
again, it is also the name of the game..........gotta pay to play...you wanna go lower, your gonna scrap ish..........get use to it, or go around the bumps....drive slower over them etc....
oh and the moving up of the shifter when hitting a bump is also caused by hitting the tranny cross member.
-J
Old Dec 15, 2009 | 06:33 AM
halfass872's Avatar
halfass872
OP....get a beater, problem solved!! Then you can be "big pimpin' " when you and your girl go out. And "slummin' " when you gotta go to Home depot! Unless you got one of those GFs that won't ride in the beater and wears those Gucci knockoff big ole' high maintnence sunglasses while doing the "fish lips" pose 24-7! If that's the case, make a choice! lol
Old Dec 15, 2009 | 06:49 AM
JasonZ-YA's Avatar
JasonZ-YA
Originally Posted by halfass872
"fish lips" pose
lol...
-J
Old Dec 15, 2009 | 07:40 AM
kevincat's Avatar
kevincat
honestly the scrapes doesnt bother me much. im just worry that if i scrape too much i might break something.
in no way will i make the car higher or back to stock, it look stupid with 19s and a kit
Old Dec 15, 2009 | 07:48 AM
jduet's Avatar
jduet
Seriously? Do you understand the adjustable height aspect of coilovers? The only way to accomplish 1 on your list is coils or going back to stock.
Old Dec 15, 2009 | 08:18 AM
  #38
_STEVEO_01's Avatar
_STEVEO_01
OP, the perfect combination for you in the ultimate of adjustability would be running air suspension WITH coilovers if your pockets can suffice. Otherwise, you would have to sacrifice your kit or just simply plan your routes accordingly. It sucks, but will save you more headaches and money in the longrun. It's just the nature of the beast. Im running my 350 on digital air as stated above, and I can assure you I can keep up with the best of them in the corners. Many options out there...
Old Dec 15, 2009 | 11:15 AM
  #39
Mike@Blackline's Avatar
Mike@Blackline
The shifter runs from the top of the transmission obviously, safely tucked into the tranny tunnel. not sure why that would be jerked.
I know what youre talking about though, im stock height and the bottom of my Z scrapes driving down the road without any bumps, any slight height difference in the road and itll do it
Old Dec 15, 2009 | 11:23 AM
  #40
cheshirecat79's Avatar
cheshirecat79
I've bottomed out several times and had the shifter jerk also. The only thing I can think of is that the tranny itself is taking the impact.
