2009 350z. Bad squeaking brake. What could it be?
Old Dec 22, 2009 | 08:05 AM
bartturner2's Avatar
bartturner2
Default 2009 350z. Bad squeaking brake. What could it be?
My cars sounds like an UPS truck. Really bad squeaking brake. Making an appointment today with Nissan. Bur curious what could this be? The car is a 2009 and only has 7,000 miles on it
Old Dec 22, 2009 | 08:12 AM
0jiggy0's Avatar
0jiggy0
I thought they stopped making the 350z in 2008.
Sounds like you need brakes.
Old Dec 22, 2009 | 08:18 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Old Dec 22, 2009 | 08:25 AM
Hexxus's Avatar
Hexxus
Roadsters were made as '09 models.
Old Dec 22, 2009 | 08:33 AM
bartturner2
But new brakes after 7,000 miles? That seems crazy. Also just had the car inspected a couple of weeks ago. Can't imagine it would pass if needed new brakes a couple of weeks later.
Also they are the Bremba brakes if that makes a difference.
Old Dec 22, 2009 | 09:23 AM
rockinbboy's Avatar
rockinbboy
well, interested to know what it is once you check with the dealership. GL.
Old Dec 22, 2009 | 09:30 AM
DavesZ#3's Avatar
DavesZ#3
There are so many things that could be causing it.
Brake dust - a build up of dust, common with OEM pads can cause squeeling.
Worn out pad - a bad could be dragging and worn down prematurely cause you to be at the wear indicator.
Your driving habits may be bad - riding the brake, hard stops, etc. Those could all wear the pads prematurely.
A lot more info is required to make a good, accurate guess. Otherwise somebody at the dealer who actually looks at the car will certainly have a better chance of telling what's the matter.
Old Dec 22, 2009 | 12:34 PM
F34RL355's Avatar
F34RL355
dont take thier its normal ********... the service manager showed me newspaper clippings of articals about breaks and asbestos and how its normal for all breaks to squeal yet to my surprise majority of cars dont squeek, he was a great ********ter
Old Dec 22, 2009 | 12:48 PM
DavesZ#3's Avatar
DavesZ#3
Ceramic brake compounds don't squeel as much as metallic and semi-metallic brakes do. Different pads squeel more than others on the same car. You're right that the majority of cars brakes don't squeel, that doesn't mean that it SHOULD be true for all cars.
High performance pads squeel like crazy but mine don't, maybe I'm doing something special to mine to minimize it
Old Dec 22, 2009 | 01:46 PM
screener's Avatar
screener
Hey my 05 with Brembo's has a nasty right rear sqeal right now. After checking the pad life they are in great shape. I noticed the noise when it became cold here in Florida, but I do have my windows up and music going usually. I think the cold weather might be adding to the intensity some, but not 100%. I will be finding the remedy and I will post here. Most likely glaze buildup, we will see.
Old Dec 23, 2009 | 08:49 AM
uglyduc's Avatar
uglyduc
If it's a street car, put some posi quiet pads in the back and call it a day. I went through 3 different types of pads before I "searched" and found the posi quiet pad fix. Problem solved.
Justin100
Nov 25, 2021 06:26 AM
350z82
Oct 1, 2015 06:25 PM
Alexreyes
Sep 30, 2015 11:30 PM
Dymsi
Sep 29, 2015 11:32 AM
