Weird ABS issue. Please help.
Old Dec 25, 2009 | 02:15 PM
mx597turbo's Avatar
mx597turbo
Question Weird ABS issue. Please help.
2003 350z. Brake fluid full, tires and brake pads/rotors both very good (Less than 25% wear).
When I first start my car and it's cold, the ABS kicks in when it shouldn't. It will engage when I'm stepping on the brakes lightly. Then while driving (not braking), the ABS, VCD Off, and SLIP lights all turn on. But if I drive the car for a while (maybe 20 minutes), I can turn the car off then on, and it works fine. The ABS doesn't kick in, and the lights don't come on.
These problems only started when the weather got cold. They go away when the car warms up and I restart.
Has anyone heard of or experienced these problems? Solutions?
Old Dec 25, 2009 | 08:10 PM
dailyBeatin's Avatar
dailyBeatin
Post your tire sizes please
Old Dec 26, 2009 | 08:36 PM
mx597turbo's Avatar
mx597turbo
The issue happened on both sets of wheels I own: currently 245/45/18 rear 225/45/18 front and my other set 275/35/19 rear and 245/35/19 front.
I bought the car in April of this year. This issue never happened until late October or November when the weather got cold. Even today, it was pretty warm, and the car was fine. I think the ABS kicked in once for only a second. No lights.
Could it possibly be that the cold is contracting the metal enough to make too much of a gap between the sensor and the hub, causing the ABS to spaz out? I read somewhere on this forum that even .01" out of spec is enough to cause problems (although I doubt this...).
Old Dec 26, 2009 | 11:31 PM
Mike@Blackline's Avatar
Mike@Blackline
in for answers, this is perplexing
Old Dec 27, 2009 | 04:16 PM
DavesZ#3's Avatar
DavesZ#3
From the FSM
In case of electrical problems with the ABS, the ABS warning lamp, VDC OFF indicator lamp and SLIP indicator lamp will turn on.
Sounds like you have a flaky ABS control module. It could be caused by a flaky wheel speed sensor or some other part of the system, but the onyl way to know for sure is to have a dealer run diagnostics on it.
Old Dec 28, 2009 | 04:35 AM
mx597turbo's Avatar
mx597turbo
Oh well, I guess I'll never know then. I have never taken any of my cars to a shop for repairs in my life, and I don't plan on starting now. I would rather drive the car with no traction control or ABS. I'm actually a little disappointed with Nissan. I have had two BMWs (an 89 and a 91), and neither ever had any problems with the ABS.
On the plus side, I drove the car yesterday. Temp was in the low 50s. It drove perfect, ABS didn't kick in at all. I guess the card really doesn't like the cold...
Old Dec 28, 2009 | 10:12 PM
gregom's Avatar
gregom
Your tire pressures good? System could be detecting too big a difference between the stagger of the front and rear wheels.
Old Dec 29, 2009 | 03:16 AM
DavesZ#3's Avatar
DavesZ#3
If tire sizes were a problem, he'd get the Slip light only and it would go off after a few seconds.
Old Dec 29, 2009 | 04:18 AM
Parker01's Avatar
Parker01
Ah a good old (and super annoying) spazzing ABS issue, a buddy of mine experienced this and tried for months to fix it.
Anyways after consulting the world and trying everything he had one last option. Some one told him that the inside of the wheel bearing/hub assembly the houses the magnetic strip for the ABS starts to corrode over time and obviously begins to cause problems as the sensor no long reads clear gaps in the magnet. This was mid summer, so I don't know if the cold had any effect on it. The syptoms he was having was under normal braking his ABS would just decide to turn on and go hay-wire... I can't remember what dash lights would come on, SLIP was on forsure... ABS/VDC I can't recall but I think they came on to, I'll try to have him chime in on this thread.
The solution was to replace the corroded wheel hub. Unfortunately since it is a sealed unit, you can't tell which is good/bad because the corrosion is on the inside. We replaced both front wheel bearings/hub assemblies on his car and the problem was gone... fixed 100%.
For reference here is the details on his car at the time:
2004 G35 6MT (Brembo, VDC equipped etc) driven all-year around
Odometer: 107,000 km (63,000miles roughly)
Season: Summer time (warm)
Also, he tried about 4 different wheel & tire combinations including his aftermarket & OEM wheels and they didn't seem to have any effect.
I hope this helps in diagnosing your problem!
Old Jan 18, 2010 | 11:01 AM
Parker01's Avatar
Parker01
Any update to this?
Old Feb 4, 2010 | 11:46 AM
kof0127's Avatar
kof0127
wow, i have the same issue and before the ABS kick in the speed went different than the actual speed then went back normal then ABS light came on, wow, if i have to change the wheel hub that will be some cost. lol any other option to solve this issue?
Old Jun 9, 2012 | 08:48 AM
rich2342's Avatar
rich2342
Is it safe to drive with this? I just started having this issue. There are no lights coming on however. The abs just seems super sensitive. Braking seems otherwise good.
I have remanned brembos new stoptech pads and rotors ..
Old Jun 9, 2012 | 09:25 AM
terrasmak's Avatar
Yes it's safe, as long as you know how to brake without ABS
Old Jun 9, 2012 | 10:38 AM
rich2342's Avatar
rich2342
why hasnt the abs light been triggered? Any ideas
aarrgghh
May 1, 2022 11:04 AM
AbrasiveRaysive
Sep 20, 2021 02:29 PM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
HoneyBadgerRy
Sep 21, 2015 03:25 PM
