How to check brake pad wear?
Old Jan 23, 2010 | 11:50 PM
xthejokerx's Avatar
xthejokerx
Default How to check brake pad wear?
quick question, do i have to remove my wheel to check my brake pad wear? also, can i just check 1 front and 1 rear instead of all 4? also, what's the correct method for checking pad wear at the indicator? thanx
Old Jan 24, 2010 | 12:07 AM
terrasmak's Avatar
Small inspection mirror and a flashlight , very simple.
Old Jan 24, 2010 | 02:58 AM
209Z33's Avatar
209Z33
I think generaly sell brake pads as set of 2 either for the front or rear don't think sell them individually, but could be wrong
Old Jan 24, 2010 | 05:08 AM
DavesZ#3's Avatar
DavesZ#3
I wouldn't check just one front and one rear, I'd check all four of them. You could have a problem and the pad you don't look at is significantly worn and fail to replace them because you didn't see a problem with the one you did look at.
samansharif
Sep 25, 2015 12:31 PM
