cusco zero 2, need help
Old Feb 10, 2010 | 04:24 AM
silents1ick's Avatar
silents1ick
Default cusco zero 2, need help
hi every1 i m buying cuscos zero2 this friday for 500, + trading my stock suspension, thing is cuscos have about 25k miles on it... wat should i look for when i go pick these up and is this a good price? 'any help appreciated
thanx
Old Feb 10, 2010 | 06:46 AM
INTIMAZY's Avatar
INTIMAZY
Check for visible oil leaks. Be prepared for a possible rebuild. Shouldn't cost too much since IIRC they use a Showa shock.
Old Feb 10, 2010 | 07:17 AM
Assume the seller will clean the coil overs so you will not see potential oil residue. Unlike dampers, coil overs are impossible to push and pull so that simple test is out of the question.
Put your money on the table and roll the dice.
Old Feb 10, 2010 | 08:32 AM
freedonutss's Avatar
freedonutss
It is possible to push and pull on a coilover but it can get tedious. Take all preload off spring then remove the top metal thing (forgot the name of this) and the spring should come off easily. Then you can push and pull on it to see if it needs a rebuild or not.
Old Feb 10, 2010 | 03:28 PM
INTIMAZY's Avatar
INTIMAZY
The rears are not true coilovers so pushing and pulling is very simple
Plus, if the suspension is still on the car (I assume it is since the seller wants the stock shocks and springs) there's a good chance you will catch leaks.
RiujinZero
Sep 25, 2015 01:19 PM
Z1 Performance
Apr 26, 2004 09:42 AM
Dec 4, 2003 09:10 PM
bobowah
May 7, 2003 09:07 PM
