Blown Shock?
Old Feb 20, 2010 | 08:59 AM
sleezye's Avatar
sleezye
Default Blown Shock?
OK, So I had 255/35/19 and 275/35/19 Toyo T1R's and had no issues with rubbing. Then I had Kuhmo SPT's put on, same sizes. On the way home from the tire place I took a local canyon and heard a clunking type noise coming from the driver rear tire.
So doing research I found end links were probably the cause so I switched them out for powergrid. Didn't fix the problem, and now I am starting to see slight rubbing on the tire. Could this be a blown shock causing the rubbing? The passenger side is fine and the sound/rubbing did not occur when I had the Toyos on. My suspension is Hotchkis springs/sways and Tockiko D Specs.
Old Feb 20, 2010 | 09:18 AM
Mike Wazowski's Avatar
Mike Wazowski
rubbing as in hit your fender?
shocks do not control the ride height, springs do. So I would not blame them on the rubbing just yet. You say the tires are the same size, but are they the actually same diameter? Just because the sizes are the same does not mean that they are exactly the same. Some brand of tires run wider then others, some run higher than others.
Do you have any pictures of said rubbing? perhaps all you need is a tad bit more negative camber.
Old Feb 20, 2010 | 10:37 AM
sleezye's Avatar
sleezye
Yea I was thinking it might have been tire size, but Its odd to only happen on one side.
Old Feb 20, 2010 | 10:51 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
check the alignment?
Old Feb 20, 2010 | 10:55 AM
sleezye's Avatar
sleezye
Here's the alignment I had done recently with the install of the End links.
Old Feb 20, 2010 | 11:00 AM
Mike Wazowski
move the rear camber to -2 and I bet the rubbing will stop. or just roll the rear fenders. I would try the camber first myself though.
Old Feb 20, 2010 | 11:43 AM
sleezye's Avatar
sleezye
Ok, I'll try that. My camber was at -1.9 before that alignment was done, and I still had rubbing sounds, but no marks on the tire yet. But I want to avoid fender rolling so I'll try the camber first.
Old Feb 20, 2010 | 11:46 AM
Mike Wazowski
the most I would go is -2.5, which is what I ran all the time in the rear of my Z
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
Nihsnek
Feb 9, 2016 12:57 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
Suffolk350z
Sep 13, 2015 02:43 PM
