brembo help..squishy break pedal
Old Feb 28, 2010 | 09:07 AM
2boosted4u's Avatar
2boosted4u
Default brembo help..squishy break pedal
so i swapped out my front rotors (backs were done a little while ago) and i was also painting my rims at the same time and got all excited to throw the rims on and forgot to pump my brakes with the cap on....soooo before i drove off i threw the cap on the master cylinder and didnt pump the brakes then when i had to stop i start pumping like crazy to get some pressure back...now my brakes are suppperrrr squishy...should bleeding them bring them back to normal?? what size rubber tubing should i buy to slip over the nipple on the caliper? anything else i should do besides bleed the breaks??
Old Feb 28, 2010 | 09:28 AM
DavesZ#3's Avatar
DavesZ#3
BRAKES - it's BRAKES.
Yes, they need to be bled.
Here's instructions that describe how to bleed properly...
https://my350z.com/forum/brakes-and-...tem-bleed.html
http://www.wikiautorepair.org/wiki/N...ing_the_Brakes
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
