please help me with suspension upgrade. need some advice .thanks!
Old Mar 5, 2010 | 05:31 PM
Z-Lover's Avatar
Z-Lover
Default please help me with suspension upgrade. need some advice .thanks!
i am thinking about upgrading the stock suspension of my 08 grand touring.
i can spend about 2000 dollars on suspension.
my main goal is to improve my Z's handling a bit for some spirit daily driving mainly on the street...i rarely take the car to the track.
also I wanna lower the car a bit more for better appearance.
i have three options in mind.
(1) nismo S tune suspension
(2) tein Basic
(3) Tein Flex.
reason why i am thinking of nismo s tune is because it's a peace of mind. but i don't know about how much can be improved in terms of handling and performance.
tein basic and flex are coilover which allows for height adjustment but i heard about them being noisy...with that rattle sound ....
should i just pick Nismo s tuned and call it a day? or pick the more complicated coilover system?
can you guys give me some advice on which one should i pick and why
thanks in advance.
Old Mar 5, 2010 | 06:01 PM
NISMO S-Tune will not lower car: https://my350z.com/forum/7715953-post34.html
Old Mar 6, 2010 | 07:55 AM
Z-Lover's Avatar
Z-Lover
thanks for the input..i knew the nismo s tune will only drop the ride by about 0.6inch. :-)
Old Mar 6, 2010 | 08:12 AM
Sickboy101's Avatar
Sickboy101
Hey Bro,
I picked up the Nismo S-tuned shocks and springs and will be installing them in the next few weeks. I didn't want an aggressive drop but I wanted the benefits of the improved steering response and reduce body lean. I'm also going to pick up a set of Hotchkis sway bars to complete my suspension set-up.
good luck
Old Mar 6, 2010 | 08:39 AM
Sickboy101's Avatar
Sickboy101
another economical option for you would the Eibach Pro Kit.
Old Mar 6, 2010 | 11:47 AM
GeauxLadyZ's Avatar
GeauxLadyZ
KW Variant 2 can be had for around 1600 or so. Amazing coilovers.
Cream of the crop = KW Variant 3's, had for almost exactly at $2000 MAX, usually cheaper.
I would go with one these over any other, imho, or a Bilstein setup.
Old Mar 6, 2010 | 12:33 PM
Voboy's Avatar
Voboy
no to tein coilovers... imo the only 2 coilovers i would suggest to you due to overall street driving would be bilstein pss or kw1/eibach pro. these offer a good range of height adjustment, and a pretty comfortable ride. no overly stiff springs. no need to figure out adjustments. and saves you a few hundred dollars to be spent else where...like rear toe/camber kit for starters.
for more info/research:
http://g35driver.com/forums/brakes-s...w-updates.html
Old Mar 6, 2010 | 07:55 PM
DerekW's Avatar
DerekW
The Bilstein PSS is a great setup. Have them matched to the spring rate (linear) of your choice and enjoy Reviews and service options are very impressive for coil-overs and this price range, please look them up.
DW
Old Mar 7, 2010 | 08:01 AM
islandsnow's Avatar
islandsnow
They are a bit overpriced, but I have had no problems with the S-tune setup with nismo sways. Probably find some on here as people tend to want to go lower, but i like the way mine has settled. Low enough, not dropped to the floor so i usually don't have to angle my way down curbs or speed bumps. Just something to think about if you're a daily driver.
Old Mar 7, 2010 | 02:04 PM
FaIRLaDiiZ's Avatar
FaIRLaDiiZ
guys thanks for all tha advice..i will consider....
btw, how is the HKS Hipermax III compare to other brands?
Old Mar 7, 2010 | 02:06 PM
FaIRLaDiiZ's Avatar
FaIRLaDiiZ
thanks for the info..i am seriously interested in Nismo s tuned..even tho it's not height adjustable..
btw, how's the handling on nismo s tuned compared to stock suspension? do you notice a big difference?
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
