NF210 or Sportlines
Old Mar 11, 2010 | 07:39 AM
elvis's Avatar
elvis
Default NF210 or Sportlines
Hey guys,
Just wondering if you guys could give me some feedback on these springs.
I'm looking for the max lowering but I also want comfort
Which ones lower more?
Which ones are stiffer?
Tanabe NF210 or Eibach sportlines
Old Mar 11, 2010 | 09:27 AM
terrasmak's Avatar
with either set, the main thing that matter for comfort will be the struts you install them on.
Old Mar 11, 2010 | 10:30 AM
duro78's Avatar
duro78
save up for coilovers wish i did
Old Mar 11, 2010 | 03:26 PM
solidfish's Avatar
solidfish
I did this research last year. From what I remember, the eibachs are the lowest drop aftermarket production springs for the Z. I cant remember the exact numbers but I think its greater than 1.25" all around (maybe more in rear).
I'm too lazy to search, which I'm guessing is your problem as well.
Old Mar 11, 2010 | 04:57 PM
elvis's Avatar
elvis
Is it really worth spending a G just to lower your car tho?
Thank you for that solidfish I thought the Tanabes would lower it more but I'm just comparing via pictures.
So stiffness is pretty much the same then for both springs?
Old Mar 11, 2010 | 09:15 PM
solidfish's Avatar
solidfish
Looks like you already know this but Eibach has two spring types for the Z. The sportlines are the ones with the crazy drop, the prokit are a more modest drop. Also note the difference between NF210 vs GF210, NF210 is 1.25" drop vs GF210 at 1.0" with slightly less spring rate.
I dont remember the numbers but I know they are posted for both the Eibachs and the Sportlines. This can be found faster through google I bet.
Old Mar 11, 2010 | 10:04 PM
terrasmak's Avatar
YES, do it right or don't do it at all.
Springs, struts, rear camber kit and alignment will set you back roughly $1k if you do the install yourself. Coilovers, rear camber kit and alignment starts around $1300 for coilovers. Just pick your path.
Old Mar 11, 2010 | 10:09 PM
solidfish's Avatar
solidfish
If you dont want an aggressive stance, many people here run the eibach prokit / gf210 with stock shocks. No need for camber kit either. Total cost: $230.
Old Mar 12, 2010 | 01:10 AM
elvis's Avatar
elvis
I do want an aggressive stance, I can run just the sportlines on stock shocks. I want to get a little bid of camber too.
Old Mar 12, 2010 | 01:35 AM
calin's Avatar
calin
If you're absolutely set on sprints and not coilovers, then I'd go with the sportlines. I loved mine when I had them
Old Mar 12, 2010 | 03:28 AM
terrasmak's Avatar
THe stock rear shocks last about 60k miles with stock spring, once lowered (especially slammed) they will wear out in 5k to 10k miles. Do it right the first time and forget about it. Then CAMBER, ok you want camber, thats cool but with out a rear camber kit you will have a rear toe problem. You will chew up rear tires, you may be able to just get away with toe bolts. Why chance it, do it right the first time.
Old Mar 12, 2010 | 03:45 AM
calin's Avatar
calin
I had my sportline springs with stock shocks for about 25-30k miles before I got my coilovers and the shocks were still good.
But OP, like terrasmak said...make sure you get a camber kit and toe bolts otherwise you will RAPE your tires
Old Mar 12, 2010 | 03:28 PM
Z_flip's Avatar
Z_flip
The NF210s aren't stiff... they're like 5% stiff from stock. They're just for lowering and keeping the same feeling.
James1990
Dec 16, 2015 08:57 PM
D'sNuts
Jun 11, 2007 07:50 PM
frizille
Mar 16, 2007 04:09 PM
chris'smax
Oct 4, 2006 06:19 PM
