squeaking/creaking rear suspension
Old Mar 21, 2010 | 06:55 PM
loquee's Avatar
loquee
Default squeaking/creaking rear suspension
Hopefully this question has not been answered 100 times before.
My rear suspension is making an annoying sound over uneven surfaces. Almost like a rubber on metal sound. I have checked and greased all bushings and everything seems to be in good condition.
I have Greddy Type-s coilovers with front and rear camber arms. My car is pretty low but no other aftermarket suspension upgrades.
I found an older post that recommended new sway bar end links.
Has anyone else had a similar experience?
Old Mar 21, 2010 | 07:08 PM
Can you put the car on a lift, and pull on the front and rear? Problem with a product like WD40 is that it will temporary hide a problem not fix it. Good luck.
Old Mar 22, 2010 | 08:49 AM
loquee's Avatar
loquee
I had the car up on jack stands and everything seemed tight. the only thing that concerned me the most was the the end links did have a lot movement. is that normal? I never really checked them before the noise.
Old Mar 22, 2010 | 09:05 AM
Russ@Z1's Avatar
Russ@Z1
upgrade rear end links
Old Mar 22, 2010 | 09:18 AM
JasonZ-YA's Avatar
JasonZ-YA
My two best guesses would be the:
1. Endlinks
2. The rear after market camber arm to aluminum sub frame lug point. usually these after market camber arms are helm rod end fittings and they make squeak/creak noises...
Spray them with some lithium grease - not WD40. WD is not for outside use....
-J
Old Mar 22, 2010 | 09:26 AM
loquee's Avatar
loquee
thanks for the advice. the aftermarket lug point is the only thing I did not grease. if this does not work, I guess I'll look into some end links
Old Mar 23, 2010 | 07:55 AM
loquee's Avatar
loquee
I think it's fixed. Thanks JasonZ-YA for pointing out the camber rod ends.
The 'eyelets' on the spherical rod ends looked to be tweaked way to the side with no room to swivel.With the help of a friend we were able to center up and re-grease the ends. We also took the sway bar bushing out and re-greased them for good measure. Did this last night and took it for a test drive. I didn't hear a sound.
Old Mar 23, 2010 | 08:55 AM
JasonZ-YA's Avatar
JasonZ-YA
yep......been there done that, thats how i knew thats what it was............glad i was able to help..
-J
Old Mar 25, 2010 | 03:14 PM
loquee's Avatar
loquee
the car sounded great for a day and the sound came back.
Anyone know how to test for worn out end links?
Old Mar 25, 2010 | 05:09 PM
Russ@Z1's Avatar
Russ@Z1
Just disconnect the end links, drive around carefully (not wildly) and see if you notice any squeaks or sounds from the rear.
350Z_Al
Oct 29, 2020 07:44 PM
