Question about basic coilover setups...
Old Apr 14, 2010 | 04:00 PM
08nogaroZ's Avatar
08nogaroZ
I read somewhere don't remember where but KW coilovers will not fit the SPL midlink which blows because I just ordered some V2's and I don't want to use SPC toe bolts .... suggestions? sorry for stealing the thread just need this question answered I appreciate it VERY much in advance
Old Apr 14, 2010 | 04:12 PM
blasian's Avatar
blasian
Originally Posted by JasonZ-YA
Ya see i know the rear shock mount bushing on the top of the rear spindle gets abused but even with all the tracking i do on my car i have yet to kill it.......its still good...
but yes, i would replace with the spl bushing over run oem coilovers any day and eliminate the need for the crappy spc toe bolts and using a spring bucket........and the cost for the spl pro midlink is not worth it to me, if that, i would rather spend more money on more coilovers..
I considered this when telling him about true coilovers because he said its a normal daily driven car.......do you really feel he will kill the shock bushing if he runs true coilovers??? im sincerely asking because every car i have worked on i have yet to see that one tear bad or be horrible, off centered or weaked yes, but not blown or eaten as you say???
-J
I remember looking at my bushing under load with the Stance coilovers and the bushing was being pushed down a good bit... like not supposed to look that good bit
It never really tore it but it appeared to put a lot of stress on a bushing as if it's not meant to handle that much of a load.
What's the deal with the SPC toe bolts? I've had them on with my Stance coilovers and my KWs
Old Apr 14, 2010 | 05:00 PM
08nogaroZ's Avatar
08nogaroZ
^^just have heard from too many people that the SPC toe bolts move around too much...was wondering if there was a different approach rather than using spc toe bolts...
Old Apr 14, 2010 | 05:18 PM
GeauxLadyZ's Avatar
GeauxLadyZ
I have read the same about the SPC bolts, i want to say SPC doesnt even use the correct grade bolt, but im not 100% on that, so please correct me if im wrong.
I believe Jason created a fix for the SPC bolt, im sure a search would pull it up in here. Maybe DIY as well, cant remember.
Old Apr 14, 2010 | 05:26 PM
08nogaroZ's Avatar
08nogaroZ
yeah I read the suspension 101 post and he did say getting a higher grade bolt and having a local shop cut a grove in it to use the eccentric washers but I was wondering if there was another way around it hahaha
Old Apr 14, 2010 | 05:29 PM
GeauxLadyZ's Avatar
GeauxLadyZ
You might be SOL
Old Apr 14, 2010 | 05:31 PM
08nogaroZ's Avatar
08nogaroZ
yeah no kidding might have to go with the fabrication process and using a grade 8 bolt or I might just try the SPC kit and see how that works out lol
Old Apr 14, 2010 | 05:33 PM
08nogaroZ's Avatar
08nogaroZ
anyways sorry for stealing your thread now back to your coilover setup lol. Good luck finding the right coilovers for your needs
Old Apr 14, 2010 | 05:52 PM
GeauxLadyZ's Avatar
GeauxLadyZ
Np broseph, feel free to ask, my questions were already answered.
Maybe he'll chime in here to let u know, but i think those are your only options.
Old Apr 14, 2010 | 06:07 PM
blasian's Avatar
blasian
I should be getting an alignment soon. I've never heard of it so I guess I'll see next time I get my alignment.
I need to get a job so I can finish what I started lol
Old Apr 14, 2010 | 06:37 PM
bimmertech's Avatar
bimmertech
the spl midlink will work with any coilover kit.
the only real thing you need to know is the rate of the spring that comes with the kw's--they are progressive, so pick what rate you want in that spread. then order the midlinks with swift spring that you want, install the eccentric lockouts and enjoy. you can even try to sell the kw rear spring/adjuster to recoup some money.
Old Apr 14, 2010 | 07:08 PM
terrasmak's Avatar
Great idea, cause someone will want to adjust the rear end better instead of doing the spring mount mod. For some odd reason they feel the need to level, or in most cases prerun the Z.
