Rotor Thickness
Old May 9, 2010 | 09:18 PM
halfrice's Avatar
halfrice
Default Rotor Thickness
So wondering if my rotors are worn too thin, did a search but all i could find was info for the 03-05 non brembo brakes.
https://my350z.com/forum/brakes-and-...thickness.html
Was wondering if anyone knew what the rotor thickness or min rotor thickness for the 06-08 non brembo brakes. Thanks
Old May 10, 2010 | 03:10 AM
DavesZ#3's Avatar
DavesZ#3
Download a copy of the FSM, it's in the Brake section. Check the sticky at the top of the Maintenance and Repair forum for link to site with FSM.
Old May 10, 2010 | 12:37 PM
halfrice's Avatar
halfrice
got this from the fsm, thought id post up in case other people wanted to know:
front
standard 28mm 1.1"
min wear 26mm 1.02"
standard 30mm 1.81"
min wear 28.4mm 1.118"
Rear
standard 16mm .630"
min wear 14mm .551"
standard 22mm .866"
min wear 20.2mm .795"
im assuming first listed in non brembo, and second listed is brembo, would make sense since brembo rotors are supposed to be thicker.
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
Stevo Z
Oct 3, 2015 09:14 PM
SharX59
Sep 30, 2015 10:54 AM
samansharif
Sep 25, 2015 12:31 PM
