Kinetix UCA's
on
I have done quite a bit of searching on this forum and I have yet to find what I am looking for. I am about to install KW variant 2 coilovers, kinetix rear camber arms, spc toe bolts, and kinetix upper control arms. I was wondering if anyone knew how many threads/ 360 degree turns must I rotate the ball joint on these control arms to get within camber spec. (between -0.6 degrees through -1.0 degrees) if I lower my car 1.5 in all around? I want to try to get the closest to spec so when I go to get my car aligned the front camber is within spec and all they have to do is adjust the front toe. I appreciate the info in advance.
thanks,
oscar
thanks,
oscar
08-06-2021 06:19 AM
