Help getting sways loose.
Hello...
I'm using my phone and searched best I could.
I'm trying to loosen the bolt on my rear sways to soften it. I tried a good 6 point socket. Impact etc. It's clearly going to strip before coming off.
I dontthink heat is good with the rubber nearby on the linkage.
I tried car on the ground... Partially jacked and both wheels up.
Any help is appreciated....
Hot hotchkis sways if that matters.
Thanks
Thanks
If it's any consolation - I couldn't get one of the nuts on my OEM rear sway off either. It's hard to get a good angle and limited space make it tough - I eventually rounded the nut meaning that I had to Dremel it. If you cut a slot in the nut, almost down to the threads, that will allow you to drive something into the slot and pop it in half.
BTW - I tried WD40, PBlaster, heating it, hammering it, etc. and nothing worked.
xirtam
Oct 3, 2015 02:06 PM
