adjusting oem style coilovers
Old Jul 29, 2010 | 10:41 PM
htownimports's Avatar
htownimports
Default adjusting oem style coilovers
just got a set of F&F coilovers, to lower the rear, do i adjust the rings on the spring or the strut? or both? ive had true coilovers before and this is my first time using one like these. thanks in advance
Old Jul 30, 2010 | 01:31 AM
Xlr82x's Avatar
Xlr82x
I believe that if you adjust the rings on the spring you will change the spring constant which will change your ride quality. The one on the strut should lower or raise.
Old Jul 30, 2010 | 08:39 AM
X.et's Avatar
X.et
You change the spring perch locking rings to lower and raise. The strut is adjusted to change droop, there are probably some threads around telling you the way to determine droop. I called f&f asking about how to adjust my droop and the guy behind the desk basically said it didn't matter how long I had it, didn't seem like the most educated response so I would see what some of the more knowledgeable people on here say.
Old Jul 30, 2010 | 05:36 PM
htownimports
thanks for the help guys, i'll try n search droop, still dont exactly understand what that means....
Old Jul 31, 2010 | 12:13 PM
Gsedan35's Avatar
Gsedan35
Adjust both, you need to maintain the right rear damper stroke range. Too short and suspension cannot extent enough, too long and your into the bumps too frequently.
350z82
Oct 1, 2015 06:25 PM
