Green Stuff Brakes
Old Nov 12, 2003 | 07:51 AM
topdown-z's Avatar
topdown-z
Lightbulb Green Stuff Brakes
I currently suffer from the excessive brake dust problem that we are all too familiar with. I've finally gotten tired of cleaning my wheels every 25 miles and decided to address the problem. I purchased a set of Green Stuff pads and have a question for those of you who have replaced your stock pads.
I don't have any problem replacing the pads myself, however, when I read the outside of the Green Stuff box, it said that they do not come with anti-rattle backing plates. In addition, it said DO NOT attempt to replace the backing plates with the used ones because it will increase the overall thickness of the Green Stuff pads, causing pad drag on the rotors.
For those of you that have changed yours, did you just remove the stock pads and backing plates then just slap in the Green Stuff pads without any backing plates or what did you do? Did you use any type of anti-squeal compound on the backs of the pads? Etc...Etc...
Any input will greatly help me
Thank You
Old Nov 12, 2003 | 08:21 AM
johnlotusboy's Avatar
johnlotusboy
I reused my backing pads and reglued them on the greenstuff pads. I had no issues with over thickness, that my two cents worth.
Old Nov 12, 2003 | 10:02 AM
Audito350Z's Avatar
Audito350Z
most auto parts stores sell some goop you can spread on the backing plates to eliminate the noise...
the only problem is, that goop gets on everything and makes it darn near impossible to remove the pads when it's time to change them later
Old Nov 12, 2003 | 10:04 AM
zwindsor's Avatar
zwindsor
Twisty addict
I put in Hawk pads and reused the stock plates. I did notice that the new pads has a slightly thicker back plate then stock. Once you push the piston back in there shouldn't be a problem. I've had no problems.
Old Nov 12, 2003 | 03:12 PM
ADMAN's Avatar
ADMAN
Hmp, no problems here either. I used the stock plates on both the front and rear pads without any goo.
However, I went with Hawk + pads all the way around instead.
ADMAN
Old Nov 14, 2003 | 12:13 PM
donpalombella's Avatar
donpalombella
Adman, how do you like the Hawk + pads?
kyin
Oct 15, 2015 05:54 AM
samansharif
Sep 25, 2015 12:31 PM
