Parking "BRAKE" light always on
Old Aug 24, 2010 | 02:03 PM
chriswalker7's Avatar
chriswalker7
Default Parking "BRAKE" light always on
Walker here again,
Along with my last post on the VDC and SLIP lights I also had the issue of my parking BRAKE light staying lit continuously.
According to NISSAN in my situation the parking BRAKE light being on is due to a bad brake master cylinder. Now Nissan wants $638 to fix this. $400 for the part and the rest for labor. I have found the master cylinder new for anywhere between $161 and $250. Install time is approx 2.5 hours.
Hope this helps
Walker
Old Aug 24, 2010 | 02:05 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
fluid is low, which is often an indicator that your pads are in bad need of replacement
Old Aug 24, 2010 | 02:27 PM
DavesZ#3's Avatar
DavesZ#3
You have to figure if somebody looked at the MC, at a minimum they would have seen that the fluid was low. But you never can tell - it's worth a quick check.
Old Aug 24, 2010 | 03:37 PM
Z1 Performance
Former Sponsor
the other thing to keep in mind, and why at a cursory look, I don't think it's a bad master, is the fact that you don't mention anything about the car not wanting to start, or stay started. The Master Cylinder represents the strongest vacuum in the car. If that diaphragm goes, the car literally won't start , or if it does, it won't stay running on it's own. FWIW, such pieces are not well known culprits on these cars, at least in my experience
Old Sep 10, 2010 | 08:41 PM
xzotklr's Avatar
xzotklr
OP..check the brake switch located on the brake pedal. It is a brown plastic casing. If this switch goes bad the brake lights will stay on.
Old Sep 10, 2010 | 11:08 PM
ndilo21's Avatar
ndilo21
He's talking about the dash indicator, not the brake lights...
Old Sep 11, 2010 | 07:09 AM
xzotklr's Avatar
xzotklr
OK...got it!! Then it is most likely the brake fluid level as stated above.
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
samansharif
Sep 25, 2015 12:31 PM
