Z Bottom Out Solution?
Old Oct 25, 2010 | 09:38 PM
htownimports's Avatar
htownimports
Default Z Bottom Out Solution?
my car is slammed and keeps bottoming out, as in the A Arm is hitting the inside of the shock tower, its getting to the point where im about to cut a hole out of the shock tower and modify it to give it room (as seen on some Civics), if theres another solution, please let me know because i want to go another half inch lower, tried searching but havent came across a solution yet. thanks guys
Old Oct 25, 2010 | 09:50 PM
terrasmak's Avatar
Raise your car, you need suspension travel for proper handling
Old Oct 25, 2010 | 10:01 PM
Neu Era's Avatar
Neu Era
+1.^^ once slammed handling sucks..
Old Oct 25, 2010 | 11:05 PM
skakemokid's Avatar
skakemokid
Make sure your shocks arn't blown. And set your dampning a little harder. Possibly even some stiffer springs.
Old Oct 26, 2010 | 03:30 AM
Flo-ridaZ33's Avatar
Flo-ridaZ33
^+1 My buddy with a VIP IS had to get the stiffest shock/spring coilover available to get his lips from hitting the fender.
Old Oct 26, 2010 | 03:47 AM
JasonZ-YA's Avatar
JasonZ-YA
RAISE YOUR CAR...............
Its a sports car, not a wake board......
The A Arm is hitting the inside of the shock tower, its getting to the point where im about to cut a hole out of the shock tower and modify it to give it room (as seen on some Civics)
If you cut anything.........please post pics!
if theres another solution, please let me know because i want to go another half inch lower, tried searching but haven't came across a solution yet. thanks guys
How exactly did you slam your car? what coilovers? what camber kit? what components all around? with that info, we can better help the issue.
also, what are you measurements front and rear as shown here?
https://my350z.com/forum/8293471-post9.html
-J
Old Oct 26, 2010 | 06:47 AM
htownimports
car is on Function Form Coilovers, with SPC camber front and rear, am i the only one with this problem? maybe i'll start pm'ing some of the Slammed guys
Old Oct 26, 2010 | 07:16 AM
JasonZ-YA's Avatar
JasonZ-YA
^ no, lots of them have this issue......most, after measuring realize that their cars dont hole a .966 ratio like mentioned in the post i linked you front/rear ratio???
most are nose dived...
People tent to install coil overs, but never tune/set them up correctly....not that there is a correct way to "slam" a car .......but there are things you can do to help avoid issues like this....ie, ensure your car's height is ratio'd correctly front vs rear; stiffer shocks, stiffer springs, proper set up in general...
-J
Old Oct 26, 2010 | 07:22 AM
betamotorsports's Avatar
betamotorsports
Raise the car.
Old Oct 26, 2010 | 07:54 AM
htownimports
-J
my rear is a tad higher than the front, i'l try lowering the rear a bit til it evens out, hopefully that'll help, thanks
Old Oct 26, 2010 | 07:58 AM
350Z_Al's Avatar
350Z_Al
I've got the same problem... I'm either going to have to preload the springs a bit, or go to a stiffer spring.... Or go to a lower profile tire in the front.. I've currently got a 245/35/18.
Old Oct 26, 2010 | 08:16 AM
AZHR's Avatar
AZHR
Seems like you are wanting someone to take the bait....so tempting....
IMO raise the car, but it's your ride. Also I don't think I would do anything I see done on a civic to my car... Just sayin, good luck...
Old Oct 26, 2010 | 09:09 AM
Gsedan35's Avatar
Gsedan35
DO NOT cut hole in the shock tower. Before you do that, shorten the front dampers 1" and add 1" of front spring preload. This will not increase spring rate, but it will increase the amount of force needed to compress the suspension to that camber arm to fender contact point.
Also, can you post pictures of your front bumpstops on the dampers?
Old Oct 26, 2010 | 05:46 PM
AJCaron12's Avatar
AJCaron12
This is seriously the dumbest thread I've ever seen... My car is slammed and I keep bottoming out what do I do? Hey I keep looking into the sun and it's really bright what do I do?
Old Oct 26, 2010 | 07:11 PM
huyrua's Avatar
huyrua
^^^LOL^^^
Old Oct 26, 2010 | 08:02 PM
sdZ33's Avatar
sdZ33
I had the same problem as OP on the same exact coils... I just raised the car up about a 1/4 inch and the problem went away...
Old Oct 26, 2010 | 08:12 PM
Entaille's Avatar
Entaille
LOL
Old Oct 26, 2010 | 09:07 PM
winchman's Avatar
winchman
If your car is a reflection of you, driving around in a slammed car makes you look stupid.
Old Oct 27, 2010 | 05:43 AM
JasonZ-YA's Avatar
JasonZ-YA
LMFAO!!! ..........classic...
-J
Old Oct 27, 2010 | 05:51 AM
derekinthez's Avatar
derekinthez
^^^ Uh, yeah dude, raise the car.
File Type: bmp
