Brake Cooling Ducts
Old Nov 18, 2003 | 12:31 PM
NTRIGUE's Avatar
NTRIGUE
Default Brake Cooling Ducts
Anyone fabricating CF brake ducts for our Z?
Old Nov 18, 2003 | 12:33 PM
NTRIGUE's Avatar
NTRIGUE
I am thinking more of a tube from the front fascia.
Old Nov 18, 2003 | 12:34 PM
NTRIGUE's Avatar
NTRIGUE
May work but...
not so clean!
Old Nov 18, 2003 | 01:30 PM
Audito350Z's Avatar
Audito350Z
in this picture you can barely make out the prototype Nick is working on for his 350Z...
http://www.ntechengineering.com/inde...number=nt00149
Old Nov 18, 2003 | 03:14 PM
mcclaskz's Avatar
mcclaskz
I should have them soon. I'll take plenty of pics when I install them. I will probably install that same 14" Stoptech as well.
Old Nov 18, 2003 | 03:49 PM
Clyde's Avatar
Clyde
Default I've ducted my fronts
I got 2 - 21/2" NACA ducts and mounted them to the lower engine cover shroud. I had a small shop weld a 21/2" pipe about 4" long to a multi-punch strap which I bolted to the turn stop on each front wheel. They angled the pipe and deformed one end so that it directed air to the center of the rotor. Removing the dust disks and attaching 21/2" ducting to the Naca ducts and these fabricated pieces I've got a pretty nice set up for cooling my front brakes. I've run 5 different schools this season and only used 1 set of Carbotech XP pads. I also changed fluid to Super Blue.
SharX59
Sep 30, 2015 10:54 AM
samansharif
Sep 25, 2015 12:31 PM
