Brake upgrade and now no pressure
Old Dec 5, 2010 | 09:49 PM
cubic202's Avatar
cubic202
Default Brake upgrade and now no pressure
Okay guys I need your assistance here.
Car 2005 350z with 40k.
I just attempted to upgrade my brakes with the following:
• Front and rear calipers and rotors from a 2007 350z; bigger rotors and twin piston calipers only 27,000miles on these
• Upgraded to stainless steel lines from Techna-fit
• Super blue DOT 4 fluid.
All items above have been installed and after 1.5 liters of fluid I still can’t build any pressure I’ve kept the MC reservoir filled during the bleeding process but so far nothing. The only thing I can point to is that the MC is unable to build up pressure.
FYI I’m doing this with a mechanic and I’m only assisting.
Your assistance is appreciated.
Old Dec 5, 2010 | 10:46 PM
terrasmak's Avatar
Its a bleed problem, PITA , and a pressure bleeder make life so much easier.
Old Dec 5, 2010 | 11:24 PM
Voboy's Avatar
Voboy
What's your bleeding procedure currently?
Reference: http://www.stoptech.com/tech_info/wp...edbrakes.shtml
Check and retorque the lines also.
Old Dec 6, 2010 | 03:18 AM
DavesZ#3's Avatar
DavesZ#3
You need to powerbleed them as mentioned above. Check these threads....
https://my350z.com/forum/brakes-and-...m-brembos.html
https://my350z.com/forum/brakes-and-...-now-soft.html
Old Dec 6, 2010 | 07:27 AM
cubic202's Avatar
cubic202
Thanks guys.
We are following the traditional bleeding method as found on the suggested Stoptech article. I was fearing the MC was damaged but I shall try the Power bleeder method…now to find one.
Thanks again.
apex locator
Jul 23, 2021 02:27 AM
