For those with Eibach Sportline
Old Mar 8, 2011 | 06:35 AM
BSERIEuS's Avatar
BSERIEuS
Originally Posted by moforeynolds
just use some blocks to get it up there dude.
As for no camber arms in the rear...well, all I can say is, I told you to get them. Most people that say you don't need them are going off of the rated drop; the problem is that once they settle, the Sportlines are FAR lower than the rated drop. I've had them, and I wouldn't have got in spec with the stock camber arms.
Originally Posted by stinky350z
ur gonna need the rear arms and toe bolt if u want ur tires to last bro , i learned the hard way lol
Thanks fellas. I will probably be placing an order for some camber arms this week. I got my car aligned last night.
here are the specs
front camber: -1.6
front toe: 0.04R 0.04L (0.08 TOTAL)
rear camber: -2.7L -3.0R
rear toe: 0.05R 0.05L (0.10 TOTAL)
The car feels so much better now from before it was aligned.
I'm not sure what the stock specs are supposed to be...I was trying to search but couldn't find the specific information i was looking for.
Old Mar 8, 2011 | 10:21 AM
terrasmak's Avatar
Rear camber arms will be nice, and get the camber back down to -1.8ish
Old Mar 14, 2011 | 08:02 AM
BSERIEuS's Avatar
BSERIEuS
I did a little online shopping/research on camber arms.
I've read about Ichiba arms failing so I think i've crossed those off my list.
I have come across these though:
http://www.conceptzperformance.com/C...766.241.32.158
any input on these particular camber arms? I was confused on the "suspension 101" thread and wasn't sure if these were crap or good if you're baullin on a budget.
https://my350z.com/forum/8293414-post5.html
Any insight or clarification would be greatly appreciated...and if those circuit sports camber arms are okay to get...i'll make the purchase today!
thanks again!
Old Mar 14, 2011 | 11:48 AM
terrasmak's Avatar
The circuit sports has some low end hiem joints in them, i would get something different.
Old Mar 14, 2011 | 01:11 PM
OSIRIS06's Avatar
OSIRIS06
eibach also makes a rear arm that works pretty good, put them on mine and never had a issue
Old Apr 5, 2011 | 05:09 PM
bjjbadboy's Avatar
bjjbadboy
Im going with the spc rear camber and toe bolts after my research seems cant go wrong quality stuff.. still having trouble on picking springs
Old Apr 7, 2011 | 05:12 PM
XSpeedAddictX's Avatar
XSpeedAddictX
What is the actual drop on our cars with these springs? I have seen 1.2 inches and 1.7-2.1 inches.
Old Apr 7, 2011 | 05:42 PM
rich2342's Avatar
rich2342
Go with the Eibach or SPC kit.. It has the non articulating ends which aren't so good.
Old Apr 7, 2011 | 06:21 PM
moforeynolds's Avatar
moforeynolds
Actual drop is about 1" lower than what Eibach claims.
Old Apr 7, 2011 | 06:35 PM
twistiert's Avatar
twistiert
Man I can't wait to install my sportlines.
Old Apr 8, 2011 | 03:50 PM
BSERIEuS's Avatar
BSERIEuS
heres a few pics i took with my point and shoot.
on some angles it seems like the rear is lower than the front...i believe its just my -2.7 camber that makes it look like that.
hope this helps anyone who's looking to buy these springs.
Old Apr 29, 2011 | 11:13 AM
BSERIEuS's Avatar
BSERIEuS
Originally Posted by tSaroya
So even if you are on stock 06 wheels (the 18X8 fronts and 18X8.5 rears), will you need to install the Upper Control Arms AND Rear Camber Arms or do you just need the Rear Camber Arms or Neither??? And what spacers do you recommend if any to get a more flush look to the back not that ghey hellaflush shitt but just so the wheel is not stuck in the fender. Thanks Guys.
i don't think you'll NEED the upper control arms but i would suggest getting the rear camber arms.
as far as spacers go...25mm rear and 15mm up front should do. H&R, ICHIBA make great spacers.
Old Jul 2, 2012 | 10:57 AM
g35maraj's Avatar
g35maraj
Default your z is sweet
what spacers are your running, and are u running any camber kits in the front?
Old Feb 24, 2014 | 05:56 PM
ATM47's Avatar
ATM47
you all need to read https://my350z.com/forum/brakes-and-...ion-101-a.html
Old Feb 24, 2014 | 06:16 PM
07maximan's Avatar
07maximan
Originally Posted by ATM47
You know this thread is over a year old, right?
Bodyboarder81
Nov 2, 2015 12:17 AM
seagrasser
Oct 11, 2015 03:27 PM
