stripped strut tower bolts
Old Mar 20, 2011 | 03:57 PM
UCF350z's Avatar
UCF350z
Default stripped strut tower bolts
So today I was changing my spark plugs and removed my strut tower brace to free up some room, everything went smooth until I went to bolt back up the strut tower. I somehow managed to strip two of them, the bolts seem to be really soft. Are these bolts that I can get at a hardware store, or am I going to have to go through the stealership?
Old Mar 20, 2011 | 06:02 PM
R3belzBRN's Avatar
R3belzBRN
u can get at any auto. shop and workshop.. just bring a sample and they can find it for u..
Old Mar 20, 2011 | 06:33 PM
All bolts are not the same. The hardware store sell bolts for home use not automotive. Get yourself some quality bolts.
Old Mar 20, 2011 | 07:48 PM
SuperBlack350z's Avatar
SuperBlack350z
you sure you didn't strip the holes instead of the bolts?
Old Mar 21, 2011 | 03:51 AM
UCF350z's Avatar
UCF350z
its def the bolts, the threads are all messed up. I hand tightened them first then started torquing them with the wrench and then they started slipping because the threads got destroyed. I have done a lot of suspension work and never had bolts strip so easily. Guess I have to be super carefull next time. Im going to the store after work to see if they carry any, I need new brake pads anyways.
Old Mar 26, 2011 | 06:38 PM
PAYBACK's Avatar
PAYBACK
When my bolts striped the holes did as well! I got them tap n dye'd for 60$ including new hardware no problems now!
Old Mar 26, 2011 | 06:57 PM
phreaktor's Avatar
phreaktor
Design Engineer
You can buy a high quality Dewalt tap and die set for half of what you paid to get them done.
Old Mar 26, 2011 | 08:08 PM
PAYBACK's Avatar
PAYBACK
well I guess If i wasnt so lazy and if I was actually broke enough to care about 60bux I might have done that...thanks for your belated advice!!!!!!
Old Mar 30, 2011 | 09:52 AM
TheDangerZone's Avatar
TheDangerZone
bolts come in different grades that why the prices can vary for the same size. Good luck with that and let us know how it works out.
Old Mar 30, 2011 | 01:54 PM
Kuhan's Avatar
Kuhan
Not sure if they change the bolt size between the years, but for my 08 350Z,
strut bolt size is
M10 x 1.25 - 20mm
I bought a few class 8.8 zinc plated steel ones to replace the strut bolts.
Old Mar 30, 2011 | 02:06 PM
Nexx's Avatar
Nexx
i say trade her in, she's done!
Old Jun 5, 2015 | 10:08 AM
Z33Garage's Avatar
Z33Garage
Happened to me, I got the bolts mentioned above but I need the size of the tap. Any info on that or can i go by the same info on the bolt for the tap?
Old Aug 14, 2015 | 05:35 PM
AbrasiveRaysive's Avatar
AbrasiveRaysive
where can I go to get this done? thanks in advance
AbrasiveRaysive
Sep 20, 2021 02:29 PM
