Brake questions
Old Mar 23, 2011 | 11:15 PM
Z33TYPE's Avatar
Z33TYPE
Default Brake questions
I am mechicanlly inclined when it comes to brakes. Ok for starters I'm not sure what it is exactly,but it sounds its metal touching or screeching to each other everytime I apply my brakes and it also makes the sound when I am making a tight right turn and now it does when I make a tight left turn and this is without braking. Everything just got worst lastnight and I have to drive about 60 miles to work. The sound goes away after driving in normal conditions,but usually when I brake or make turns.
Its coming from my rear passenger side. I am not too sure if it could be rotors, brake pads.
Old Mar 24, 2011 | 12:06 AM
terrasmak's Avatar
Pads, just change them. Simple and easy job. If you do it yourself its only about $20
Old Mar 24, 2011 | 01:33 AM
winchman's Avatar
winchman
If it's not the pads, check the wheel bearings.
Old Mar 24, 2011 | 03:21 AM
The pad includes a metal wear indicator that will touch the rotor. It is designed to work that way.
Noise when turning? I don't know. The wheels, rotors and callipers are in the same position when turning.
Old Mar 24, 2011 | 10:42 AM
winchman's Avatar
winchman
If the bearings are loose, the rotors will move more than usual because of the side loads when turning corners.
samansharif
Sep 25, 2015 12:31 PM
