2008 VQ35HR Brembos on a 2004 Roadster?
Old Mar 30, 2011 | 01:17 AM
siliconesteve's Avatar
siliconesteve
Default 2008 VQ35HR Brembos on a 2004 Roadster?
I have a line on a set of used Brembo Calipers off a 2008 350Z with a VQ35HR engine. Does any one know if the Calipers will fit a 2004 350Z Roadster (non Brembo).
Old Mar 30, 2011 | 05:04 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
you need everything - calipers, brackets, pads, hardware, rotors, lines
Old Mar 31, 2011 | 03:20 AM
siliconesteve
The brackets Can I get them off a 2008 350Z? Or will I need to buy them off a fabricator?? If yes do you know of one??? The hardware, lines and rotors I’m assuming I can get them from Nissan????
Old Mar 31, 2011 | 04:57 AM
Z1 Performance
Former Sponsor
you need the complete setup as listed from the brembo equipped car
fabricating your own brackets will be cost prohibitive
Old Apr 1, 2011 | 10:07 AM
Chris_B's Avatar
Chris_B
If you are referring to the OE Brembo's (Track Model or Nismo), then they will bolt right on to an '04 as long as you use the correct rotors (your current ones won't work). The calipers are lug mount, so they don't use brackets. Just be sure you do front and rear so the bias is as intended.
Chris
Stevo Z
Oct 3, 2015 09:14 PM
_bit
Oct 2, 2015 07:49 AM
