Rear Shock Stud Broke - NEED HELP!!!
Old Apr 18, 2011 | 02:07 AM
bikinilust's Avatar
bikinilust
Default Rear Shock Stud Broke - NEED HELP!!!
please delete
bikinilust's Avatar
bikinilust
Ive searched the forum, but no luck on finding any info on this
Old Apr 18, 2011 | 05:54 AM
phreaktor's Avatar
phreaktor
Design Engineer
Cut it off flush and try knocking it out with a heavy metal mallet and a center punch. Or cold chisel/die grind the head off from inside and knock it out. Not sure what it looks like inside though. Maybe try drilling it out with a carbide bit and knocking out the remainder with a brass plumb bob? Post some pics of it inside and out. Vise grips?
Old Apr 18, 2011 | 06:02 AM
06blueZ's Avatar
06blueZ
https://my350z.com/forum/brakes-and-...hat-to-do.html
Old Apr 18, 2011 | 10:54 AM
bikinilust's Avatar
bikinilust
updated pic
Old Apr 20, 2011 | 06:47 PM
JasonZ-YA's Avatar
JasonZ-YA
this pic:
I say grind it flush, drill it out to a hole, reach in and drop a M8 bolt through - grade 10.9 if you can find it with large washers...
using extension from top, hold the head of the bolt and tighten nut from bottom...
stock is M8x1.25 pitch, but you can use whatever pitch you want.....
length - measure the adjacent bolt length and accommodate for washer thickness, etc...
-J
