Camber or Bushing.
Old 05-01-2011, 09:21 PM
zlatan
zlatan's Avatar
Default Camber or Bushing.
Hello Ladies and Gents,
I've recently put my car on coilovers and stanced it. Sure I know not everyone is going to like it and that's fine. However, I've come across an issue that I was trying to figure out. The car feels like it's dancing past 70mph. I keep the wheel straight; however the car feels like it wiggles left and right. Now my compression rod bushings are toast and I've ordered some SPL's, however my car is running -6 degrees of camber in the rear. I'm trying to figure out if its more of a camber issue or bushing. Here is a photo:
Thank you,
Zlatan
Old 05-01-2011, 09:28 PM
SuperBlack350z
SuperBlack350z's Avatar
sounds like toe i believe?
Old 05-01-2011, 09:31 PM
terrasmak's Avatar
Received 2,290 Likes on 1,650 Posts
Replace the compression bushings, LCA bushings need to be looked at. BTW you Lowered the car, i know your trying so hard be be cool and all, but its just called lowering.
Old 05-01-2011, 09:43 PM
zlatan
zlatan's Avatar
Your the most jaded person I've ever seen on a forum. All your responses are structured in a smart *** way. I really and honestly believe you need to take a deep breath and focus on finding some peace within yourself. Thank you for the advice, try not to be such an *** all the time with the little bit of helpful knowledge you throw around like your Jesus in his 2nd coming.
Old 05-01-2011, 10:19 PM
JDMStanced
JDMStanced's Avatar
go lower
What front camber arm are you running?
Old 05-01-2011, 10:29 PM
SoldzMyZ
SoldzMyZ's Avatar
LOL welp at first I was like "stance" wtf
and then his response to you I was like,
But your respoonse I was like Eloquent response bravo!
Old 05-01-2011, 10:48 PM
JasonZ-YA
JasonZ-YA's Avatar
stanced.................lol...........here we go..........
-J
Old 05-02-2011, 01:20 AM
winchman
winchman's Avatar
Did you follow the SM instructions on tightening the bolt on the lower end of the shock absorber? If not, you may have damaged the bushing in the axle housing. It's not supposed to be tightened fully until the car is on the ground.
Old 05-02-2011, 06:13 AM
zlatan
zlatan's Avatar
I did thanks.
Old 05-02-2011, 06:21 AM
zlatan
zlatan's Avatar
Originally Posted by JDMStanced
go lower
Ichiba arms. I can't really go much lower. I already can't get into my work driveway.
Old 05-02-2011, 07:05 AM
bmccann101
bmccann101's Avatar
Default yep
what he said.. thats toe for sure.
Old 05-02-2011, 07:08 AM
bmccann101
bmccann101's Avatar
at +10k posts, youre allowed to be an @ss btw.. haha.
Grandpa'd rights.. hey.... it is what it is.
Old 05-02-2011, 07:49 AM
terrasmak's Avatar
Once you have the bushing problem fixed and the car properly aligned it will tell you more. -6 camber is a lot, you are operating with suspension geometry set up in a way it is not even close to being deligned to operate in.
I know at the front -2.7 i run the car tracks a little strange on the road, i'm sure -6 is a bit different. Then you throw bump, and lack of proper suspension movement into the mix, weird stuff will happen.
Old 05-02-2011, 08:28 AM
JDMStanced
JDMStanced's Avatar
how are you suppose to tighten the bracket bolt when wheel is mounted?
I always torque down the bracket on my rear coilover when the car is in the air.
Old 05-02-2011, 11:32 AM
skakemokid
skakemokid's Avatar
^lower the car on some big pieces of wood...
08-06-2021 06:19 AM
HoBrahYouStink
06-24-2016 10:58 PM
350Z Project X
Suspension
10-10-2015 09:23 AM
Rowlett
Misc.
10-02-2015 10:38 AM
Quick Reply: Camber or Bushing.
