Changing springs to linear on KW Coilovers
Old May 28, 2011 | 12:47 AM
halfrice's Avatar
halfrice
Default Changing springs to linear on KW Coilovers
looking to change out my v3 springs for swift linear springs. does anyone know the height of the kw springs? I like the ride height just want linear springs, and also for the fronts what pillowballs are you guys running, and what id springs for front and rear?
Old Jun 3, 2011 | 05:52 AM
vtchang's Avatar
vtchang
front ~234mm, rear ? mm . Front might be a little harder to do because the spring tapers in diameter. You could always find a larger perch for the front.
Others have used Eibach ESS or ERS in the rear. I tried 230mm BC BR Rear OEM style linear springs, but it slams the rear. If you want them, you can have them for $50. If you're not interested in the slammed look, you may want to go with the 9.5"+ option.
Please let me know if you find anything. Been interested too.
-Ray
