Need Info: 2 purple dots only on rear spring?
Old Jun 5, 2011 | 12:37 PM
Purplemonkey's Avatar
Purplemonkey
Default Need Info: 2 purple dots only on rear spring?
Hi everyone, just looking for some info. I've tried searching and haven't found anything...
I am looking to buy a set of stock Z springs and when I met up with the guy, the markings on the springs where as follows:
Front - 1 purple only
Rear - 2 purple only
I couldn't find any reference to these markings. The springs supposedly came off a 2006 350Z convertible.
Any help would be much appreciated!!
[Plan to put them on an 06 G35 coupe - wife's car]
Old Jun 5, 2011 | 03:39 PM
bmccann101's Avatar
bmccann101
z springs are not the same as g springs.,. diff rates.
Old Jun 5, 2011 | 05:01 PM
Rocknthehawk's Avatar
Rocknthehawk
stock Z springs will lower a G.
I just checked the stock suspension i saved from my 04, the rear spring i grabbed (didn't check both) had two red dots, and one purple. The one front I looked at had a single pink dot.
Old Jun 6, 2011 | 08:42 AM
Purplemonkey
I'm aware that they are different spring rates - that is not the issue. I've looked around and read about the unrevised vs revised springs, etc...
What I need help with is what springs these are.
