Changed brake pads, car got jacked up???
Old Jun 22, 2011 | 09:41 AM
glacier's Avatar
glacier
Exclamation Changed brake pads, car got jacked up???
This is going to sound very weird, but here goes:
I took my car to my mechanic to install newly purchased Brembo pads (my old ones are running thin, squeaking).
I also had them install StopTech SS lines at the same time.
I left the car at the garage for about a few hours, and when picking up the car, I noticed the car is now riding a lot higher! I can now fit almost 4 fingers in the rear wheel gap!
The mechanic insisted that what I am describing is impossible, as there's nothing he could've done to raise the car.
Am I just seeing things?
Old Jun 22, 2011 | 09:44 AM
glacier's Avatar
glacier
Fortunately, I happen to have a picture of the car BEFORE I took it to the garage, so attached is a BEFORE and AFTER comparison.
The car does not look like it's higher, does it?
I've always thought stock height is just too much, maybe this mentality is causing me to see things???
Old Jun 22, 2011 | 09:47 AM
glacier's Avatar
glacier
And here are current photos of front and rear fender gap.
Front is tight 3 fingers. Rear is loose 3 fingers.
on stock suspension.
Do these look right?
Attached Thumbnails Changed brake pads, car got jacked up???-dsc06679.jpg   Changed brake pads, car got jacked up???-dsc06680.jpg
Old Jun 22, 2011 | 10:01 AM
winchman's Avatar
winchman
My '08 is the same: Front 3F tight, rear 3F loose.
Old Jun 22, 2011 | 10:06 AM
glacier's Avatar
glacier
Right. And mine is a 2008 as well.
Old Jun 22, 2011 | 10:50 AM
sry110's Avatar
sry110
Wait...your first post says the car is now riding higher than before you took it to the shop, and then the rest of the posts are saying that it's not really any different than before you took it in....or did I mis-read that?
For whatever it's worth, everytime I let my car come back to the ground after jacking it up and unloading the suspension, it sits higher than before I lifted it. Then by the time I drive it out of the neighborhood, it's back to normal. I'm not sure why that happens, but it does, and it always goes back to normal.
Old Jun 22, 2011 | 10:51 AM
glacier's Avatar
glacier
^^^ For some reason, my eyes told me that the car was riding higher than before.
But this morning, when I took pics to compare (as you can see), it seems like the car is back to stock height again.
I think you are probably right---------it needs the "settle"???
Old Jun 22, 2011 | 12:39 PM
NZMOWND's Avatar
NZMOWND
Yep let me springs settle back down and it should be all good!
Old Jun 22, 2011 | 12:41 PM
cubu's Avatar
cubu
yes, the joints and bushings need to settle, a short drive should do it
Old Jun 22, 2011 | 12:48 PM
glacier's Avatar
glacier
Thanks guys for the help!
Old Jun 23, 2011 | 08:43 AM
exZilaration's Avatar
exZilaration
[QUOTE=glacier;9216965]And here are current photos of front and rear fender gap.
Thats what she said
JjL
East Canada
Jun 12, 2019 03:04 AM
ZXoltan
Brakes
19
Nov 25, 2015 04:21 AM
SonnyWu
Nov 24, 2015 08:19 PM
RWDBajan
Sep 17, 2015 04:52 PM
Alex Tappin
Sep 9, 2015 08:18 PM
