Rear camber bolt subframe cutting template
Old Jun 24, 2011 | 11:16 AM
phreaktor's Avatar
phreaktor
Design Engineer
Angry Rear camber bolt subframe cutting template
Does anyone have it and if so can you post it here? I have Ichiba rear arms..
Old Jun 24, 2011 | 11:46 AM
sry110's Avatar
sry110
Technically I think you are referring to the template for the toe bolt, right? I have the one at home for the SPC / Eibach toe bolt hole but I'm not sure it's the same as the Ichiba. Plus I won't be home until next week to post it up.
EDIT: Blammo: https://my350z.com/forum/brakes-and-...-template.html
Old Jun 24, 2011 | 05:23 PM
Marcus93's Avatar
Marcus93
Sweet good post, I just got my Ichiba camber arms & toe bolts too.
Old Jun 24, 2011 | 05:33 PM
Glex25's Avatar
Glex25
I got the template here Phreak
I was doing someone's camber install last weekend and still got
one of the templates here
Old Jun 25, 2011 | 04:43 PM
phreaktor's Avatar
phreaktor
Design Engineer
Nah, it's def for the camber arms. The hole on the subframe that needs to be enlarged...
Old Jun 25, 2011 | 04:44 PM
phreaktor's Avatar
phreaktor
Design Engineer
WHere are you located?
Old Jun 25, 2011 | 04:47 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
^ Torrey, it may be where the camber arm is bolted through, but the enlarging of hole is to allow for greater toe adjustment (since the camber arm throws it off by changing the length). What sry110 is actually what you're looking for.
Old Jun 25, 2011 | 06:47 PM
phreaktor's Avatar
phreaktor
Design Engineer
Ah you are correct. Not sure what the hell I was thinking, lol.. The pic in the link he provided shows it is exactly 1 inch wide. Which direction does it need to be opened up? Toward the center of the car or the wheels? Or both?
Old Jun 25, 2011 | 07:14 PM
3hree5ive0ero
Retired Admin
When you put the template on, you'll be dremeling out toward both wheels.
Old Jun 26, 2011 | 03:59 AM
Glex25's Avatar
Glex25
Come to the meet tonight in Willowbrook mall that is posted in the Northeast section and I will give it you
