Rubbing when going up driveways...
Old Jul 3, 2011 | 12:35 AM
jkim824's Avatar
jkim824
Default Rubbing when going up driveways...
So I'm dropped on Stance coilovers with 18x9.5/10.5 +15 RPF1. Tire specs are 245/40 and 275/35. So pretty much when I go up driveways and all the load is on one wheel, my tires rub pretty badly. I believe my camber spec up front is around -2.2. I was just seeking some advice on how to fix this issue. Will I need to roll the front fenders more than they already are? add more camber? maybe different tires? Any advice will be much appreciated.
Thank you
Old Jul 3, 2011 | 01:19 AM
BrandonHeat's Avatar
BrandonHeat
Did you remove splash guard in wheel well? That may be what your rubbing on.
Old Jul 3, 2011 | 06:29 AM
chris05ppwZ's Avatar
chris05ppwZ
I'm going to guess its your tire sizes, best way to tell is to jack the car up and either roll and pull or just cut some **** out....How low are you?
Old Jul 3, 2011 | 06:35 AM
midz350's Avatar
midz350
I think the front fenders are already rolled, check the rear ones.
Old Jul 3, 2011 | 07:28 AM
drivessidewayz's Avatar
drivessidewayz
Pics? Drop? Which tire is rubbing, the loaded or unloaded one(s)?
Old Jul 3, 2011 | 07:38 AM
jkim824's Avatar
jkim824
Its the fronts that are rubbing and it rubs on the very edge of the fender. It usually only happens when i do a right turn into a driveway because all the weight is on the right wheel.
The only pic I have right now
Old Jul 3, 2011 | 09:15 AM
Phenom's Avatar
Phenom
Toasty
Originally Posted by jkim824
So I'm dropped
I've identified the culprit.
Old Jul 3, 2011 | 10:35 AM
Where is Captain Obvious?
Old Jul 7, 2011 | 06:44 AM
35028's Avatar
35028
Have you stiffened the fronts to 15?
Old Jul 7, 2011 | 09:30 AM
terrasmak's Avatar
Thats weird, with those some wheels and 275/35-18's up front at -2.2 i didn't rub. I would bet you don't have your coilovers set up properly. You probably need more shock body lenght and less preload. Also remove the screw from the inner fender, cut in in half , reinstall and fold the tab in more.
BTW, you have front tires mounted on the rear of your car, you should have 275/40 out back.
Old Jul 7, 2011 | 10:22 AM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
Do NOT preload coilovers. The ONLY reason there is even a preload adjustment is for corner balancing. All height should be adjusted via the shock body, and the spring should have no tension with the suspension unloaded.
Other than that, what happens if you make a similar left turn? Does the left side rub? If only 1 side is doing it, then you've got either a suspension setup problem or the fender is rolled more on one side that the other. Either of these should be pretty easy to correct.
416blueZ
Jun 11, 2024 10:56 AM
dboyzalter
North East Marketplace
15
May 6, 2018 09:41 AM
hulkout
Apr 28, 2017 09:00 PM
416blueZ
Sep 24, 2015 02:11 PM
waldo36
Sep 20, 2015 09:13 PM
