Need help.. Abs, slip, vdc off lights on when braking
Old Jul 8, 2011 | 05:45 PM
maximariceboi's Avatar
maximariceboi
Default Need help.. Abs, slip, vdc off lights on when braking
First time encountering this issue..as I was driving I went through a slight dip on the road and applied the brakes..the abs, slip and vdc off light comes on. I turned off the car and stepped on the brakes again, the lights show up. Also I turned the car off again.. Stepped on the brakes, started up the car, I felt a the brake pedal pulsated with a noise.
Abs pump going bad? Abs sensor? I'll have to jack up the car and look in the morning. Just trying to see if anyone encountered this problem and have a fix for this.
Edit:
New power slot rotors front and rear (2 months ago)
New nismo pads front and rear (2 months ago)
Fluids recently checked today and is full.
Thanks in advance
Eric
Old Jul 8, 2011 | 05:47 PM
DB350's Avatar
DB350
check fluid
check pads
report back
also:
maximariceboi
Garage is empty, add now
Points: 2,271, Level: 28
Today's Activity: 3.1%
gtfo devil
Old Jul 8, 2011 | 05:52 PM
DavesZ#3's Avatar
DavesZ#3
Yeap, low brake fluid and/or worn pads.
Old Jul 8, 2011 | 07:45 PM
maximariceboi
Gtfo devil? Lol because of my post count? It was well over a 1000 last year.. And currently using my phone on the forum.
You forgot to point out i have a decent amount of itrader feedback
Originally Posted by DB350
check fluid
check pads
report back
also:
maximariceboi
gtfo devil
Old Jul 8, 2011 | 07:52 PM
maximariceboi
That's odd.. I installed brand new power slot rotors And brand new nismo pads for my brembo brakes 2 months ago. I forgot to mention earlier fluid levels are fine.
Old Jul 8, 2011 | 08:37 PM
R3belzBRN's Avatar
R3belzBRN
check ur fluidd
Old Jul 8, 2011 | 09:01 PM
maximariceboi
Originally Posted by R3belzBRN
check ur fluidd
Already checked and it's full
Old Jul 8, 2011 | 09:55 PM
winchman's Avatar
winchman
"Stepped on the brakes, started up the car, I felt a the brake pedal pulsated with a noise."
That's the ABS doing its usual self-test. You won't feel it if your foot isn't on the pedal, but you might hear the sound.
Old Jul 8, 2011 | 10:25 PM
maximariceboi
Ah ok good to know thanks!
Old Jul 8, 2011 | 11:45 PM
tony530's Avatar
tony530
Ok start ur car and foot completely of the brake!.. Then turn engine off....pump the brake? How many pump till it get hard!? Or is it spongy??
Old Jul 9, 2011 | 03:16 AM
R3belzBRN's Avatar
R3belzBRN
thats what i did when i had the problem. i did topup the fluid.but still i got the lights...switch off the engine and pump till it get hard.. start the engine and its gone till now..
Old Jul 9, 2011 | 08:35 AM
maximariceboi
Just stepping on the brake pedal all the way down also causes the lights to show up.. I don't see any leaks either.. The car drives normally but not sure if the abs actually works.
Old Jul 9, 2011 | 10:26 AM
tony530's Avatar
tony530
Sound like u have air in your abs or brake system Gonna need a scan tool and bleed each on the abs out or a wheel speed sensor went bad!? ....o and never top off your fluid!! That when u you check for leaks!!! It gotta go somewhere!!
Old Jul 9, 2011 | 03:40 PM
maximariceboi
I just looked at the brake master cylinder and there's actually more fluids in there than yesterday..ill have to take some out tomorrow.
Old Jul 10, 2011 | 02:27 PM
maximariceboi
Found out today my brake lights are not working. Fuses are fine..So possibly the brake light switch on the brake pedal? Thanks in advance.
350z82
Oct 1, 2015 06:25 PM
