should I change diff/subframe bushings?
Old Jul 29, 2011 | 12:12 AM
jdm-v35's Avatar
jdm-v35
Default should I change diff/subframe bushings?
I have been doing a ton of research on the subject over the past couple weeks but cant find anything very conclusive. theres lots of DIY but not much reviews.
I have an 03 G35 coupe with 54k on it.
I have to change a couole worn front LCA bushings so I bought the energy suspension front and rear bushing sets.
Im debating whether its worth it to do the diff and subframe bushings at the same time. theyre not blown but itd just be for precautionary measures as well as minor response gains. is it worth it? and is there a good chance of them failing soon?
and if I do decide to do it im trying to decide between energy suspension poly or solid aluminum bushings for the diff and subframe.
any help is appreciated. thanks in advance.
Old Jul 29, 2011 | 01:13 AM
0jiggy0's Avatar
0jiggy0
Diff yes but the solid aluminum type are the best. Subframe is a lot more work to get out to replace. That's up to you. Mods?
Old Jul 29, 2011 | 09:38 AM
jdm-v35's Avatar
jdm-v35
I would probably pay a shop to change all the bushings since I dont have a press to take them all out. But what are the chances of diff or subframe bushings failing? I dont abuse the car at all really. maybe push it once a month.
no major power mods. lwt popcharger with polished ztube, stillen HFC, greddy EVo TT exhaust, polished inner plenum, accessport, VB mod, trans cooler
suspension: HKS RS coils, stillen sways, ichiba front A arms, spc rear camber arms and toe bolts, upgraded to brembos with SS lines and drilled rotors, richie front STB
Old Jul 29, 2011 | 10:38 AM
bmccann101's Avatar
bmccann101
the usual way to do the rear diff bushing is to DROP the subframe out, so doing those bushings will add little cost.
IF you already have poly, use em. SOlid is cool ( i have em) but it does add some whine... but comapred to solid eng and trans bushings... its NOTHING.
Id do it all day long bro. Expect 6-7 hours labor. You will never do it again tho even if theres a nuclear holocaust.
Old Jul 29, 2011 | 11:21 AM
KhanMan's Avatar
KhanMan
I had to replace my control arm bushings, and compression rod bushings for the front(will do sub-frame later). I went stock for the compression rod and whiteline for the whole LCA and it I can tell you that the urethane are very nice. I don't fully remember how well sedan did with the stock but with this I feel the steering is more stable even on rough roads.
Old Jul 29, 2011 | 01:24 PM
jdm-v35's Avatar
jdm-v35
so you think solid is significantly better than poly?
Old Jul 29, 2011 | 01:39 PM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
Solid is way better than poly. The solids will never need replacement, either. Keep in mind that you'll get slightly more vibration inside the car, but it's well worth it in my opinion.
Old Jul 29, 2011 | 01:45 PM
bmccann101's Avatar
bmccann101
50/50 OP.. Vivids correct, but it is more harsh, prepare for new squeaks and rattles along w the increasing in humming ( and not the good kind ha).
Diff bushings and rear subframe? SOlid is beuno.
Front end and steering stuff? meh.. i wouldnt if you drive the car for enjoyment daily..
youre not screwed w poly at all either.. its a huge upgrade from the rubber oem, still has a little isolation to it too.. solid is metal to metal period.
GREAT for the diff bushings.. decent for the rear due to axle hop, high stress etc... but the front end stuff is what you have your hands on daily.. ( steering wheel) id stay softer up front unles you are serious about this build as a racer. Its far more expenseive to go solid up front.
this is my experience and is what is in my car. Solid in back, poly up front. thats all i can attest to.
Old Jul 29, 2011 | 04:06 PM
jdm-v35's Avatar
jdm-v35
sounds good.
im probably going to get the sikky raised subframe bushings and either energy poly or sikky solid diff bushings.
I will stay poly up front and poly on the rear arms.
thanks for all the advice.
I read in a thread that poly iss not a good material for the rear diff bushing. is this true?
Old Jul 29, 2011 | 08:28 PM
jdm-v35's Avatar
jdm-v35
nvm. just decided and put my order in for sikky raised subframe and diff solid bushings! hope they work out well.
Old Sep 30, 2011 | 01:04 PM
sanbaifo's Avatar
sanbaifo
Have you installed them yet? What are your impressions?
I'm thinking about doing the same but may go all poly instead.
Old Jun 25, 2012 | 05:31 PM
sanbaifo's Avatar
sanbaifo
So, how do you like them?
Old Jun 25, 2012 | 05:57 PM
terrasmak's Avatar
I have the same set up, great , just not a daily driver thing to do
Old Jun 25, 2012 | 06:11 PM
rich2342's Avatar
rich2342
Whats the best poly kit to get for the rear diff(mine is torn)? Im DD and track, dont want the added noise, God knows I have enough with my sway bar bushings..
Old Jun 26, 2012 | 12:31 PM
sanbaifo's Avatar
sanbaifo
Probably the Whiteline kit (KDT911)
Old Jul 5, 2012 | 03:56 AM
JasonZ-YA's Avatar
JasonZ-YA
I have the same set up...track car only though as well..
love it..
-J
Old Jul 5, 2012 | 04:00 AM
JasonZ-YA's Avatar
JasonZ-YA
Smile
yes! hands down, if your gonna go with a NON solid diff bushing set up, ie, your car is a dailly driver or occasional autoX weekend worrier then do the KDT911 whiteline kit.
See here:
https://my350z.com/forum/9781609-post16.html
https://my350z.com/forum/8293651-post24.html
-J
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
