Squeaking
Hey guys. I starting to get some squeak every time I take turns sliwly or if I got over a speedbomp slowly. My friends are telling me thar my balljoins are just getting dry and all I need is to grease them up. But to be honest I have no idea what's wrong and I would truly appreciate if anyone can give me a hand how to fix this
Yes they are sealed, but I still agree with what DavidV said. You can poke a little pinhole in tie rod and ball joint boots with a pic, then attach a straw to a can of PB blaster or WD40 and stick the straw in the boot where you just made the pin hole and spray. Like David said, if it goes away when you do that, bingo.
There is a thin paper gasket between the top of the shock mount (part of the shock absorber assembly) and the underside of the fender well. You'll probably find it's dried up and cracking into pieces when you remove the upper end of the shock from the car body.
I'm convinced the shock absorber itself is the source of a chirping sound associated with hitting small bumps at low speeds. The noise goes away completely for several days after I drive the car for more than hour, but comes back after several days of sitting in the garage or daily short trips. Large movements of the shock don't make the noise.
I think it's caused by gas getting into the valve in the shock, because the noise sounds just like air in the valves of a hydraulic system. Getting the shock hot on a long drive forces the gas away from the valve.
My friend jut told me to get a grease gun and get a little needle. Attach the needle to the grease gun and eject some grease in the ball joInts... What you guys think??
lol winchman thanks for the re-assurance.
No it won't. Not from a pinhole. I've done it more than once. It won't **** grease, trust me. And it takes a while for leaking boots to cause a joint to go bad. One of my lower balljoint boots has been pissing grease since the day I bought the car. I'm just too lazy to replace it lol.
You also open the joint to moisture & debris.
Whatever you do, DO NOT poke holes in your boots & spray WD-40 in your balljoints...
