Akebono install
Old Oct 9, 2011 | 02:06 PM
Escobar's Avatar
Escobar
Question Akebono install
Just installed the akebono bbk on my Z and I must say I am quite impresssed with them, however today when I first drove it it had a vibration when I applied the brakes. It shook the whole car a bit, like the pedal was going in and out a bit, almost like the rotor was warped? Any ideas? I blead the brakes right, both sides of the calpiers.
Old Oct 9, 2011 | 02:11 PM
Flo-ridaZ33's Avatar
Flo-ridaZ33
General rule of thumb is you bleed all 4 calipers... Start with the caliper farthest away from the master cylinder. I would recheck if everything is tightened correctly. Sounds to me like you need to bleed them correctly.
Old Oct 9, 2011 | 02:37 PM
Escobar's Avatar
Escobar
Yea I definitely blead all 4 calipers. They have a bleed screw on both the front and back of the caliper.
Old Oct 9, 2011 | 04:10 PM
lgear080's Avatar
lgear080
Did you bed thoroughly?
Old Oct 9, 2011 | 06:29 PM
beezee's Avatar
beezee
Took a while to completely bleed mine. Each time I thought I was done, I got bubbles when I tapped the calipers a bit. It won't hurt to try bleeding again
Old Oct 9, 2011 | 06:52 PM
ksmoore's Avatar
ksmoore
did you make sure everything was "set" in place while bolting it back up?
Old Oct 9, 2011 | 07:00 PM
Escobar's Avatar
Escobar
they are ceramic pads, no need to...however I did do some hard braking from 70-10 a few times.
Old Oct 9, 2011 | 07:01 PM
Escobar's Avatar
Escobar
yeah, I will go around again and make sure there is no more air, its just a weird feeling the pedal moving up and down.
Old Oct 9, 2011 | 07:02 PM
Escobar's Avatar
Escobar
what do you mean?
Old Oct 9, 2011 | 07:28 PM
ksmoore's Avatar
ksmoore
Originally Posted by Escobar
what do you mean?
i mean was everything (rotor, caliper brackets and such) was "set" in place with no play, even though you tightened it down?
Old Oct 9, 2011 | 07:50 PM
lgear080's Avatar
lgear080
I've never heard of a setup that didn't require bedding.
were they new when you installed? rotors and all?
i'd do that too..
Old Oct 9, 2011 | 10:20 PM
Flo-ridaZ33
Keep in mind I have a set of Akebono's... I've never heard of the pedel going up and down and it be a warped rotor. The shaking and the fact that your having the weird pedel pulsation makes me think that their's still air in the lines or something is loose.
Old Oct 10, 2011 | 04:02 AM
Escobar's Avatar
Escobar
Yea, I'm thinking there is some air I didn't get out..I'll try bleeding them a few more times. As far as the fit, everything was tight and was torqued to 115 ft lbs I'n the front and 70 I'n the rear. The pulsation I'n the pedal is what puzzles me.
Old Oct 10, 2011 | 04:25 AM
=Cerberus='s Avatar
=Cerberus=
Sounds more like an ABS engagement then air in the line. Air will just make the pedal hit the floor, no bouncing up an down. However when the ABS kicks in it can pulse the pedal.
When you changed over to the new calipers, did you let the brake line hang for a while?
Old Oct 10, 2011 | 04:32 AM
Escobar's Avatar
Escobar
yea I took off the old brake system and let the fluid in the line drain out, there was still quite a bit of fluid in all the lines when I re blead them with the super blue. Its just an odd feeling, even if you barely touch the brake I can feel the pedal pulse. Maybe I just have a pad in wrong, dont see how but I'll double check.
Old Oct 10, 2011 | 04:38 AM
Escobar's Avatar
Escobar
i'd do that too..
could of sworn it said no break in on the box, however I did break them in a bit anyway. Everything was brand new from CZP.
Old Oct 10, 2011 | 05:41 AM
lgear080's Avatar
lgear080
huh... interesting. hope the re-bleed solves your conundrum.
Old Oct 10, 2011 | 06:28 AM
SlowCoupe's Avatar
SlowCoupe
Your rotors may not be seated on the hub properly. Or the rotors may have been dropped and warped.
Old Oct 10, 2011 | 11:10 AM
beezee's Avatar
beezee
I bet letting the fluid drain out is at least part of the problem (if not all). It becomes more difficult to completely get the system air-free. The instructions that come with the CZP kit tells you to plug the lines with one of the bleeder cups once you disconnect the line. Maybe one or two drips within the few seconds between disconnect and connect. I am not saying you are stuck. Or I am saying is, you will have to bleed the system longer than you probably did.
I have had the CZP kit as well for some months now and so far so good.
I used the Motive Power bleeder. It made the job easier
Old Oct 10, 2011 | 11:42 AM
Flo-ridaZ33
+1 on the Motive bleeder... I didn't let the whole system go dry either.
