Akebono install
Old Oct 24, 2011 | 03:39 AM
  #61
Escobar's Avatar
Escobar
Originally Posted by Tougelabs
Sorry to be off topic but did you have brembos on your car ? I have an offer on my stock brembos and was thinking about picking up the akebonos and putting a nice set of pads on them etc.
I had just the oem brakes, no brembos. I would go for it, the akebonos are massive and look great. Beside my small issue, I love the way they brake.
  #62
Escobar's Avatar
Escobar
Originally Posted by beezee
Well i ca't see the graduation on that indicator but if it is a .0001 you have about .0009 total runout. If it is a .0005 you have about .0045.
Its a .001 graduation.
Old Oct 24, 2011 | 09:42 AM
  #63
beezee's Avatar
beezee
If so then you have a lot of runout. You measure total runout by counting the number of "lines" between the highest and lowest reading. In your case it amounts to about .009 which is quite a lot unless i am not seeing the video right.
Old Oct 24, 2011 | 01:46 PM
  #64
ian99rt's Avatar
ian99rt
Yep thats way too much runout.
Heres mine at the hub:
Old Oct 24, 2011 | 04:23 PM
  #65
Escobar's Avatar
Escobar
yeah, you are seeing the video right. I got new rotors coming, hopefully that will take care of it.
Old Oct 24, 2011 | 04:24 PM
  #66
Escobar's Avatar
Escobar
I need to check it at the hub too, my old brakes were fine but maybe I just didnt notice since the rotors were smaller.
Old Nov 2, 2011 | 09:14 AM
  #67
Escobar's Avatar
Escobar
Got the new rotors in today, going to slap them on and see if it helps.
Old Nov 2, 2011 | 03:19 PM
  #68
Escobar's Avatar
Escobar
got the new rotors on and it is a little better but still not perfect. here is a video of the spindle, is this too mcuh out? It moves 3 clicks back and forth...each one is .001, so its .003 out. According to the FSM, .002 or less is acceptable so Im thinking the hub is in need of replacing. I guess I'll order up two of them,.
http://s1214.photobucket.com/albums/...t=IMG_1338.mp4
<embed type="application/x-shockwave-flash" allowfullscreen="true" allownetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf" flashvars="file=http%3A%2F%2Fvid1214.photobucket.com%2Falbum s%2Fcc484%2Fescobar211%2F350z%2FIMG_1338.mp4" width="600" height="361">
Old Nov 6, 2011 | 06:28 AM
  #69
Escobar's Avatar
Escobar
Just to give you guys a heads up the saga is over, turns out it was the front hubs. Replaced them and everything is perfect. Thanks for all your input.
