fortune auto dreadnaught. drool
Old Nov 2, 2011 | 01:41 AM
J 0 K 3 R's Avatar
J 0 K 3 R
Originally Posted by SE5spd
275/295 eh?
what kinda tires? sidewall height height?
rims you are putting them on. Dont be surprised if you feel your car handles worst after putting them on, stock suspension is actually pretty decent.
if i like the oem setup better then the 1000$ suspension will just have to be for my slammed on 19's setup (i have to go over at leat 10 speed bumps to get to my current apartment.)
23lb 18x10 wheels (i wont mention the brand lol)
hankook v12's with 30 sidewalls.
what size tires were yours in venice? i dont remember the width and height. they were beefy. and you still runnin that setup?
Old Nov 2, 2011 | 01:58 AM
terrasmak's Avatar
Originally Posted by J 0 K 3 R
tho i think sway bars make the car feel like its handling better but the same amount of g force is pulling the car at the tires in a turn. i am getting mad rear axle hop and bump steer. if the car is grabbing at high speed thru a turn and hits any slight bumpiness and the back end gets a lil loose and wants to hang out the rest of the turn, i have to do a low angle drift out of every turn even downhill.
Mad axle hop leaving a corner, would equal one of two main things. Worn rear shocks or to aggressive on the gas. Proper shocks will help, an LSD will help a lot, learning how to drive will also help.
BTW bump steer will get worse when lowered, unless you get some tie rod ends that are adjustable.
Last, take it to the track. If you want to learn how to drive fast, and really push your car, leave the street in your past.
Old Nov 2, 2011 | 02:04 AM
J 0 K 3 R's Avatar
J 0 K 3 R
thanks for the info as always terrasmak.mulholland is not really the street. tanner foust even picked it to show off his insane drift skills. going to mazda leguna seca and infinion as soon as i can after i get these tires.
Old Nov 2, 2011 | 02:13 AM
terrasmak's Avatar
It is a street, has traffic flowing in two directions and you can/will be ticketed for driving like a jackwagon on it.
http://www.speedventures.com/events/Default.aspx plenty of events to choose from.
If you plan to do trackdays, i highly suggest looking for something other than V12's. They are great street tires, but after 2 to 3 events you will want/need a better tire.
Old Nov 2, 2011 | 02:23 AM
J 0 K 3 R's Avatar
J 0 K 3 R
the v12s are mainly for the street and probably one or 2 track runs. i will pick up some used track tires when i go. was looking to get some from member scotts300 a couple weeks ago but my drag race against uti got cancelled. (Scotts i'll be hittin you up for tires later.)
Old Nov 2, 2011 | 02:25 AM
KingBaby's Avatar
KingBaby
Hardest Setting
Lol
That's why I asked for vids! I wanted to know how your burning all fours!
Old Nov 2, 2011 | 02:32 AM
J 0 K 3 R's Avatar
J 0 K 3 R
Originally Posted by KingBaby
Lol
yeah its from braking ha. down hill coming up to a tight turn hit brakes make turn while on brakes, all four tires slide up to the apex, hit the gas, back tires break loose, tail goes out, and maintain same slight angle out of turn and repeat for the next one lol.
Old Nov 2, 2011 | 02:59 AM
terrasmak's Avatar
Suspension is not going to help that at all, and with stiffer spring rates it will slide even more.
Old Nov 2, 2011 | 03:52 AM
VQ35deMax's Avatar
VQ35deMax
Fortune Auto coilovers are actually not crap. Had a set of them on an S chasis and loved them. Plus they provide a shock dyno with every coilover set and you could actually see how well the shocks perform. Then you can match them up with Swift springs and have one killer of a bang for your buck coilover set-up.
People bash on them because they have no experience or think that since it is a smaller brand, they must be crap.
Old Nov 2, 2011 | 11:10 AM
J 0 K 3 R's Avatar
J 0 K 3 R
the wide tires should. and id like to pick a company that has tons of spring rates to switch around from. are swift springs known/considered to be better than bc or megan?
yeah i like the helper springs they offer too. seems like they would help a lot on the street. any suspension that i can adjust firmness with should make the car do what i want. =corner on rails.
and i agree. ive never heard anyone say i had x brand coil and it was worse than stock.
Old Nov 2, 2011 | 12:13 PM
SE5spd's Avatar
SE5spd
you are gonna switch suspension everytime you want to go to the track?
they dont make 255/30 275/30 V12s, and I would never use V12s for track tires..
I have 265/35 285/35 on a 9.5/10.5
mullholland is a public street with cops and speed limits.
let me know when you are going to the track, ill sign up to the same one. You should hit up thunderhill though, more n00b friendly
which tires are you buying from him?
swift is way better then BC/MEGAN
stiff does not mean you will handle like you are on rail necessarily.
you need to read up more on suspension before purchasing anything, or better yet don't get coilovers, buy brakes and a clutch type LSD and go to the track like that, until you max out your driving skills like that you don't need to worry about suspension upgrades.
Old Nov 2, 2011 | 02:38 PM
J 0 K 3 R's Avatar
J 0 K 3 R
good advice bro i might have to do a 35 series if they dont have 30's. Im down for thunderhill I'll let you know.
I dont knowwhat tires he will have when i need em. whatever will work.
yeah ive read all about the stiff suspension being too stiff and you need the perfect balance, which i think i will get with enough adjustability, and maybe helper springs.
you should know i drive the ***** off that car and am waaay maxing it out thats unanimous amongst people that have seen me drive it end of that discussion, no one could even see my car after 30secnds when i blasted off with that turbo 240 during the caravan.
Old Nov 2, 2011 | 02:59 PM
CCDesigns's Avatar
CCDesigns
If this is really how your driving on public streets please stop driving. take it to the track and learn how to drive properly, having a stiffer suspension will only make your driving style worse
Old Nov 2, 2011 | 04:41 PM
Flo-ridaZ33's Avatar
Flo-ridaZ33
Yet you ask if anyone likes me? You hav to be the biggest tool on this site.
Old Nov 2, 2011 | 05:21 PM
Waiz's Avatar
Waiz
Meaningless thread about parts that aren't even available for a Z has run it's course....
burglapfd
Dec 6, 2020 01:04 PM
Jambo016
Sep 16, 2016 01:08 PM
_bit
Oct 2, 2015 07:49 AM
jlc280z
Sep 24, 2015 08:43 AM
